What sensor malfunctions will throw the computer into Limp Mode - Ford Truck Enthusiasts Forums
Old 04-06-2012, 01:40 AM
john165 john165 is offline
john165 is starting off with a positive reputation.
I picked up a 1984 F250 4x4 with an Inline 6 the other day. The reason behind the purchase was because I always wanted a 4x4. Anyway the feedback system was not in use, which wasnt a bother to me because I plan on fixing this truck up. It needs some stuff done to it, and it is a big improvement over my 84 f250 Inline 6 2wd. My 2wd is a rust bucket LITERALLY lol. The motor and tranny in the 2wd are strong, i meam really strong even thou it is in Limp mode too!
So the 4x4, I want to fix up and transfer the motor over to it and have the 4 speed trans rebuilt, which I was told was an NP and it grinds the 2nd gear which I havent fully yet determined as to what the cause is whether the clutch or the syncros. And I dont know where the id tag is or stamp???
Now, like what the title said, what sensor malfunctions, will throw the computer into Limp Mode? I am debating on whether to replace all sensor's or change the 4x4 over to Duraspark? So far I have added the money up to $234 for the MAP, FEEDBACK, TPS, OXYGEN, BOWL VENT. I dont know about the emission connectors attached to the valve cover, whether they do work and if they dont if they are still available? If the Dura spark conversion is cost effective verses bringing the computer out of limp mode then I would do that. Thats why I need to know what sensors and solenoids have to work with the computer so I would have the variable timing curve and not the fixed timing? Thanks.
Old 04-06-2012, 08:47 AM
klricks klricks is offline
klricks is starting off with a positive reputation.
What codes do you have?
Old 04-06-2012, 09:21 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
What if you have a wiring or connector problem? Replacing the sensors won't fix that.
Unverified trouble codes Maathiu Ra Yin Electrical Systems/Wiring 1 10-18-2016 10:37 AM
Code 41 with/feedback carb blue84f250 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 05-20-2013 12:23 AM
04 F150 Limp Mode ChrisCarter 2004 - 2008 F150 0 01-26-2012 11:24 AM
"LIMP MODE" BigBlack4004 Explorer, Sport Trac, Mountaineer & Aviator 3 06-01-2011 06:22 PM
2003 6.0 Diesel (Safe or Limp Mode) ICP sensor G5.4 6.0L Power Stroke Diesel 4 04-29-2011 12:17 AM
Tags
2000, 2011, 67, 86, computer, elimination, expedition, f150, ford, limp, malfunction, mode, propane, taurus, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
