Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 04-06-2012, 12:25 AM
ssmorsi ssmorsi is offline
Garage is empty, add now
ssmorsi is starting off with a positive reputation.
Possible bad fuel pump
Folks, I'v searched this forum and tried some of the trouble shooting tips but want to run everything by you guys just to make sure.
My 2001 4.6L F-150 has been sitting on the driveway, used once every 2 weeks or so for the last 3 yrs. I came to start it a few days ago and it kept turning over but not starting. The key security chip is working, battery is charged, all plugs are firing, fuel pump fuse and relay check good. When I turn the key to ON, sometimes I hear the fuel pump priming, other times it doesn't. The times it does prime, the truck fires right up. The times it doesn't prime, engine won't start. When the pump does prime, and while the engine is running, the pump makes a noticeable buzzing sound, much louder than normal. When the pump primes. fuel pressure measures at 42psi in the ON position, 36psi with engine running, and 46psi with engine running and vacuum hose removed. I believe all these are within specs.
My question is this: Is it safe to assume that the pump is going bad and will eventually fail completely? My second question is (and I know this can be debated til the end of time) should I get the Motorcraft ($288) or aftermarket? I have Airtex, Spectra, Carter, and Delphi ($165 - $210) available locally.
Thanks folks...
  #2 (permalink)
Old 04-06-2012, 05:29 AM
phil6608's Avatar
phil6608 phil6608 is offline
phil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant future
The prices you are give must be for the hole fuel pump assembly, or your really getting riped off..lol
If you need a pump, you only need to replace the pump, not the hole deal.
You can get all the pumps on rockauto . com for under 100 bucks.
The motorcraft looks to be pretty high on there though.
__________________
( Phil )2003 SuperCrew: JLP Built Lightning block/Stage 3 heads and cams.
L-conversion/Kenne Bell upgrade blower at 16PSI/BTS,4R100 tranny/100 shot nitrous.
594HP/620TQ Without the Nitrous 1.68 60' time/11.76 @ 116.17 with the 100 shot.
Join the the Delaware Chapter, HERE
  #3 (permalink)
Old 04-06-2012, 11:46 AM
kidzstang kidzstang is offline
kidzstang is starting off with a positive reputation.
You can check for bad fuel pump two ways. The best is to check the fuel pressure on the rail. It should be like 38 or higher.
You can also spray.some starting fluid in the throttle body when it doesn't fire. If it sputters like it wants to start then you can assume the fuel pump is on the way out.
__________________
Jack
  #4 (permalink)
Old 04-06-2012, 02:27 PM
canacka canacka is offline
canacka is starting off with a positive reputation.
Check the electrical connection to the pump. That buzzing you here may be arcing. Also check your ground, that may be loose as well.
  #5 (permalink)
Old 04-08-2012, 06:45 PM
blue2golf's Avatar
blue2golf blue2golf is offline
blue2golf is starting off with a positive reputation.
My truck did the same thing last year. If you heard the pump buzzing, truck would start. No buzz, no start. I had a mechanic check the fuel pressure. I can't remember the exact reading but I know it was too low.
I dropped the tank and replaced the whole unit with an Airtex from Advance Auto. About $150 or so (again, I can't remember exact price.) If you're going to pull the bed or drop the tank to change out the pump, you might as well change the whole unit out. Dropping that tank was a bear, I wouldn't want to do it to replace a pump, then drop it again for a sending unit later on.
It's been about a year since I installed the Airtex. No problems.
__________________
Fishbowl of Bud, Ma'am.
Tags
1997, 351, 390, 50, bad, carter, dephi, f150, filter, ford, fuel, loud, pump, truck, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
