Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 04-06-2012, 12:22 AM
Gruntface Gruntface is offline
Garage is empty, add now
Gruntface is starting off with a positive reputation.
What do these codes mean?
I got my Auto Enginuity and ran the test. These are the codes I got.
B1352-Ignition key-in circuit failure intrument cluster
B2425-remote keyless entry out of sync vsm
P1000-monitor checks not complete-more driving required
P0603-inernal control module KAM error
P1248-turbo boost pressure not detected
P0683-glow plug control module to pcmcommunication circuit
Well any help on where to start with these to fix them would be greatly apreciated. Thanks for looking.
  #2 (permalink)
Old 04-06-2012, 12:39 AM
carltonwebb's Avatar
carltonwebb carltonwebb is offline
carltonwebb has a very good reputation on FTE.carltonwebb has a very good reputation on FTE.carltonwebb has a very good reputation on FTE.
Welcome to guzzle's Diagnostic Trouble Code list Web Page
That should give u the info u need.
__________________
2000 Ford F-250 Supercab, 7.3 PSD, Auto, Bone Stock, 199,400k. 08 SD tailgate.
2011 Ford Escape Limited, V-6, For the wife.
  #3 (permalink)
Old 04-06-2012, 01:59 AM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
2000 Ford F-350
BigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud of
Are you having any issues? Driveability issues? MAP line hooked up?
__________________
Alan 2000 F-350 CC SRW 4WD, DIY FRx, DIY CCK, Tyrant Tuning, BTS Trans, SpringerPop's Disabler, 6637 Filter, ZooDad, OCR, DIY Hutch Mod, Gutted EBPV, Foil Delete, 50Cent Mod, Muffler delete, other stuff...277,000 Miles and counting.Towing 2005 32' Sandpiper 5'er
2007 F-250 CCSB 4WD-Stock 73,000 miles.
Member Arkansas Chapter
  #4 (permalink)
Old 04-06-2012, 07:46 AM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale
2000 Ford F-250
Tugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant future
Quote:
B1352
B2425
P1000
P0603
P1248
P0683
Well any help on where to start with these would be greatly apreciated. Thanks for looking.
When you want to know the codes, this will help.
  #5 (permalink)
Old 04-06-2012, 10:30 AM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is online now
1999 Ford F-250
Shake-N-Bake has a brilliant futureShake-N-Bake has a brilliant futureShake-N-Bake has a brilliant futureShake-N-Bake has a brilliant futureShake-N-Bake has a brilliant futureShake-N-Bake has a brilliant futureShake-N-Bake has a brilliant futureShake-N-Bake has a brilliant futureShake-N-Bake has a brilliant futureShake-N-Bake has a brilliant futureShake-N-Bake has a brilliant future
B1352
B2425
P1000
P0603
P1248
P0683
"B" is for Body and "P" is for Powertrain
B1352 DSM (Driver's Seat Module)....Sounds like you have an Excursion and the module isn't connected or possibly faulty.
B2425 you need to reprogram your key fobs for remote keyless entry
P1000 you need to drive your truck for a while so the PCM can check all the systems. This code will go away on it's own after a while.
P0603 Your batteries have been disconnected or the PCM was removed from the system recently.
P0683 There is some problem with your glow plug control module.
P1248 Boost not detected. This one you need to fix. Check and see if your MAP sensor is connected properly. There should be a hose that looks like a vacuum line that runs from the sensor to the intake manifold (spider). Check and see if this hose is broken, cut or disconnected. Also check the electrical connector to make sure it's seated properly. The red locking tab should slide all the way up towards the sensor...
__________________
Greg
Alvin ('99 F-250 306k CC 4x4 XLT PSD red)-Theo ('00 F-250 202k CC 4x4 Lariat PSD white)-Simon ('00 F-450 197k CC Lariat white)
  #6 (permalink)
Old 04-06-2012, 10:48 AM
Sorry I knew what the little descriptions were but I don't know what they mean in english. The glow plug to pcm circuit I believe is that my uvch is fried, yes maybe? The one about boost pressure is because I turned the truck on with my boots off. But the others I dont know what they want me to do to fix them. What do you guys think
  #7 (permalink)
Old 04-06-2012, 11:16 AM
Snake-n-Bake my 1352 description is different than what u described or is what u described what the code means?
  #8 (permalink)
Old 04-06-2012, 11:24 AM
cleatus12r cleatus12r is offline
cleatus12r has much to be proud ofcleatus12r has much to be proud ofcleatus12r has much to be proud ofcleatus12r has much to be proud ofcleatus12r has much to be proud ofcleatus12r has much to be proud ofcleatus12r has much to be proud ofcleatus12r has much to be proud ofcleatus12r has much to be proud of
I'll save you some time on this one; no.
The glow plug control module communicates to the PCM through the engine wiring harness, not the valve cover harness. If you have a problem with the glow plug wiring through the harness under the valve cover, you will end up with individual glow plug failure codes.
__________________
2000 F250 PSD Regular Cab 2wd with an automatic. One hundred percent stock except for having 250/200% injectors running at stock power output.
1995 F250 PSD SuperCab longbox 4wd with an automatic. Also all-stock.
  #9 (permalink)
Old 04-06-2012, 11:46 AM
1999 Ford F-250
I am mistaken. I misread the code and looked up B1342 by accident.
Your code is describing some sort of issue with the ignition key circuit. Can be caused a dozens of various things. Most likely an isolated incident. Clear your codes, drive around and see what returns.
Sorry, I am of no help with the glow plug control module. I've never touched one of those things...
__________________
Greg
  #10 (permalink)
Old 04-06-2012, 12:18 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
Support FTE
1999 Ford F-250
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Do you get a chime when key is in ignition and you open the door? I've always got the B1352 code whenever I hook up AE. I did the key in ignition chime delete and that might be why.
  #11 (permalink)
Old 04-06-2012, 06:44 PM
Snake-N-Bake,
Thanks for the pic. I forgot to reattach the vacuum line to the map sensor when I put everything back together after changing my glow plugs and doing th e.50 cent mod. I got the ae and fixed that tube and cleared the engine codes and everything is great no more codes. Thanks guys for responding. Now that I got that cleared what tests should I do with the ae.
Thanks guys
  #12 (permalink)
Old 04-07-2012, 05:16 AM
Tugly's Avatar
2000 Ford F-250
Snake-N-Bake,
Thanks guys
KOEO - MAP sensor and EBP sensor should be within 1.3 PSI of your altitude pressure (12 PSI 6000 ft, 14.7 PSI sea level) I did the buzz test before the first engine start of the day, activated things I can't hear when the engine is running, you can do the cylinder contribution test, blah-blah-blah. I bought the 7.3L Powerstroke Diesel Powertrain Control/Emissions Diagnosis (PC/ED) and the Excursion/Superduty Wiring Diagrams for my year of truck. I got mine at Amazon, but ebay has them too. This book is the Ford engine analyzer accompaniment.
While those tests can yield some obvious stuff like a bad injector solenoid or a bad MAP sensor, the real gain for me was driving with AE recording. I always record MPH and RPM to get a reference to where I am - you can see starts, stops, city, highways, etc.... I also need to know under what conditions something specific happens. I can give you a shopping list of items to record when testing the HPOP:
  1. MPH
  2. RPM
  3. Injector Control Pressure
  4. Injector Control Pressure Duty Cycle
  5. Fuel Injector Pulse Width
  6. Accelerator Position Voltage
I conducted several acceleration test with different tunes and I was lucky to hook up to another truck to compare the data. My HPOP is bad - new one coming.
  #13 (permalink)
Old 04-07-2012, 12:03 PM
PaysonPSD's Avatar
Support FTE
1999 Ford F-250
Ken (woodnthings) has some great AE info HERE.
Tags
12, 1352, 2000, 2003, 59, b1352, b2425, body, code, codes, diesel, expedition, f250, ford, pcm, stored, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
