4x4 help on my 79 - Ford Truck Enthusiasts Forums
4x4 help on my 79
Old 04-06-2012, 01:17 AM
joel79ford joel79ford is offline
joel79ford is starting off with a positive reputation.
4x4 help on my 79
I used my 4x4 for the first time today
And after I free'd the hubs in the front, I shiffted it back into 2wd hi
Though the front bar kept spinning though?
I mean at idle, the bar dosent move but when I shift into first or second gear it starts to move
is this normal? I've never really payed attention to my 4x4 until now
Old 04-06-2012, 10:05 AM
F-250 WARHORSE's Avatar
F-250 WARHORSE F-250 WARHORSE is offline
F-250 WARHORSE is gaining momentum as a positive member of FTE.F-250 WARHORSE is gaining momentum as a positive member of FTE.
I would climb under your truck and see if there is any free wheel capability of the front drive shaft. I bet it isn't disengaged at the transfer case or at the hubs.
Old 04-06-2012, 07:59 PM
Yeah, i tried again and moved the 4x4 shifter around a couple of times
and the hubs but the shaft spins very slowley when i go in first gear or reverse
SO this is not normal right?
iv heard on SOME trucks it is, is it on mine?
Old 04-07-2012, 12:59 AM
77&79F250's Avatar
77&79F250 77&79F250 is online now
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
To get it into 4wd....
1. lock in hubs
2. shift transfer lever into required range 4 H or 4 L
3. 4 wheel the hell out it.....
Ok done pulling the chebby off the wet grass.
1. Put transfer case lever back to 2wd, I let my arm rest on the seat as a way to feel the slip from 4H to 2H since its gradual.
2. Get out and un lock both hubs
3. Drive truck backwards a few feet (some say 15)
I always slowly drive left and right a bit and ck for that feeling that a hub/hubs are not locked in anymore.
And yes the front axles and d/s can coast spin as I call it.... as long as it NOT be driven by the transfer case. Another way to make sure you are in 2wd is put xfer case in N the 1 notch back.
Old 04-07-2012, 06:15 PM
GOVTMOD GOVTMOD is offline
GOVTMOD is gaining momentum as a positive member of FTE.GOVTMOD is gaining momentum as a positive member of FTE.
Old 04-08-2012, 01:22 AM
piratius's Avatar
piratius piratius is offline
piratius is starting off with a positive reputation.
My transfer case doesn't have "notches" as it shifts - should it? All the other 4x4's I've owed have been Jeeps, which have really obvious transfer case engagement. I may need to twin stick in the near future to make sure I'm doing it right!
I usually just put it in neutral, then pull it back until it drives (2wd) and leave it
-B
Old 04-08-2012, 09:56 AM
earthquake68's Avatar
earthquake68 earthquake68 is offline
earthquake68 has a very good reputation on FTE.earthquake68 has a very good reputation on FTE.earthquake68 has a very good reputation on FTE.
What transfer case do you have? The detents should be fairly obvious. Any chance the clip popped off the t-case shifter and the lever isn't moving the selector arm on the T-case?
Old 04-08-2012, 10:01 PM
piratius's Avatar
Quote:
It's an NP205. probably worn out as all heck inside
-Brad
77.5-79 Dana 44 f250 front sway bar and links crazed87bronco Ford Truck Parts for Sale 1 11-28-2015 09:21 PM
Sources for front sway bar after D60 SAS? LeoJr 1987 - 1996 F150 & Larger F-Series Trucks 7 09-10-2015 08:54 AM
death wobble, installed tapered track bar bolt, still has wobble 6ohman2004 1973 - 1979 F-100 & Larger F-Series Trucks 13 08-29-2014 10:01 PM
Anybody Running Fender Well Headers on 78/79 F250 4X4 w/Front Sway Bar? twinzilla 1973 - 1979 F-100 & Larger F-Series Trucks 4 06-19-2014 08:42 AM
torque bar or ladder bars? booger78 Offroad & 4x4 14 03-04-2012 01:51 PM
Tags
4x4, 79
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
