New Ram - great thread!
The new Ram doesn't look to bad, but why would you want your motor to shut off at every stop? Seems like that would wear out your starter quick and cause a bit of a delay when you want to start accelerating again. The motor could just run on 4 cylinders at a stop, that way it would still save fuel but keep the motor running. Also, can you manually adjust the air ride suspension or is it automatic?
From the website for the air ride suspension:
Air pressure increases until the vehicle reaches normal ride height, leveling the truck and improving the loaded ride. It has five height settings that operate automatically or via console or key fob controls:
Normal Ride Height (NRH): 8.7 inches of clearance (from the base of the door sill) is the default, load-leveled ride height
Aero: Lowers the Ram by 1.1 inches, increasing gas mileage by up to 1%. It is activated by speed.
Off-road 1 and 2: Lifts the vehicle 1.2 and 2 inches, respectively, to clear obstacles
Park: Lowers the truck by 2 inches from NRH for easy entry/exit and cargo loading
No I haven't driven a Toyota Prius. I didn't realize that they also had a start/stop system. I guess I would rather keep the motor running than shut it off to save a bit of fuel, maybe if I lived in a big city it would make more sense with all the stop lights/signs. Also if your towing a heavy load and your motor shuts off at every stop, wouldn't that cause wear and tear on the motor?
I would personally leave the engine running at a stop light, Just for the simple reason is the Manufacturer be it Dodge, Toyota..etc.... DON'T have to pay to replace the starter! The owner does!
If the vehicle is out of warranty and you take it ( or have it towed...because it won’t start) to a dealership to replace a starter...at dealership prices plus labor.
Even if you changed the starter yourself in your driveway... The hassle of having to get the vehicle towed home ( unless you change it where it died... grocery store parking lot, gas station..) Then get to the part store to buy a new starter...etc... everyone here knows the hassle.
The cost of fuel idling at a stop light is probably WAY cheaper than the extra wear and tear on the starter.
just my 2 cents..
just my 2 cents..
They are really throwing a lot of tech into these trucks - at least the loaded ones.
I, like many of you are wondering about reliability for some of these features, but chrysler still offers a lifetime warranty that you can purchase. Approx $1800 for maxcare lifetime with $100 deductible, and they are actually pretty damn good about honoring stuff at higher mileages...
These new ram 1/2 tons look great, looking forward to all these features showing up across Ford and GM, looks like the next couple years are gonna be great for innovation.
just my 2 cents..
just my 2 cents..
They are w/o a doubt on the right track now. But as been alluded to here before WHY don't the regular cab trucks get the same more impressive interior packages as the crew series?
I like the **** selector instead of stick and the push button start technology is a real plus. But Ford has them all beat with their key pad door opener.
Why they're waiting for late summer on the 2013 line doesn't really make much sense however.
