1974 Highboy - Stuck in 4WD - Ford Truck Enthusiasts Forums
Old 04-05-2012, 09:04 PM
Paul Trahan Paul Trahan is offline
Paul Trahan is starting off with a positive reputation.
I just bought this truck and have been getting it running a bit at a time. Most recently, I replaced the red ***** on the hubs, reassembled them, and ran into a problem testing them. I locked the hubs, put the shifter in 4WD Low, and drove a few feet. When I try to unlock the hubs, they won't unlock, and the shifter won't move.
I don't know what to do and would appreciate any help.
Old 04-05-2012, 09:12 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
You've got it in a "bind".
Old 04-05-2012, 10:09 PM
Any thoughts on how to get out of the bind?
Old 04-05-2012, 10:19 PM
critterf1's Avatar
Jack up the front and try to unlock. I'd almost bet the front and rear gears don't match.
Old 04-05-2012, 10:32 PM
I will give it a try. Does this mean I can't use my 4WD until I fix something else?
Old 04-06-2012, 01:27 PM
I jacked up the rear, the tires spun a bit and freed something up (maybe the transfer case). This freed up the 4WD shifter and allowed me to turn the hubs to Free. Now, I just need to figure out what I did in the first place to cause it to lock up.
Old 04-06-2012, 01:37 PM
70 Bronco TX's Avatar
70 Bronco TX 70 Bronco TX is offline
70 Bronco TX is starting off with a positive reputation.
I always (usually only need to with my Bronco) back up about 15 feet. That seems to loosen up the hubs.
Old 04-06-2012, 01:49 PM
77&79F250's Avatar
77&79F250 77&79F250 is offline
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
Did you reassemble the lock in/out correctly and did you re-install them with them in the locked in or out position? You can do that ya know?
If everything is correctly assembled and installed properly.....next question, is it parked on pavement or a concrete driveway? And does it have any roll pressure on it?
With in idling and in drive, keep constant steady pressure on the transfer case stick while trying to pull it (transfer case lever ) out of gear, and just bump the throttle a small bit.
Then try the same thing with it in reverse, and you might unbind the drive line. Driving on hard packed surface (pavement/driveway) can cause that.
Until figured out whats wrong do NOT drive it on pavement!
Old 04-06-2012, 01:59 PM
gfw1985's Avatar
gfw1985 gfw1985 is offline
Cranky Old Guy
gfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to all
All good points. #1 cause of locking these old trucks up is someone new to the old technology. They just don't work the same as newer vehicles.
Old 04-06-2012, 04:38 PM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
Technically, as per the factory manual, you're supposed to place the transfer case in 2wd before you disengage the hubs,
but even this does not always work, in that case just drive in reverse 10-15 feet and this will allow you to disengage the hubs as well as the shifter.
Old 04-06-2012, 06:03 PM
I assembled the hubs correctly, and they appear to be working fine now. The problem was the lockup. I will what the manual says and then try backing up if that does not work. Both are a lot easier than jacking up the read end. And, it sounds like I need to keep it out of 4WD on dry pavement.
Thanks for the great information.
Old 04-06-2012, 11:38 PM
77&79F250's Avatar
Used OEM parts guy
Yes Yes and a big NO 4wd on pavement great way to really break stuff.
Locking Hubs and 4x4 CO Wapiti 2017 Super Duty 16 11-30-2016 06:26 PM
Hubs won't unlock 2002exPSD Excursion - King of SUVs 1 08-26-2016 07:42 AM
Hub question - they won't unlock! Ed in Maine 1999 to 2016 Super Duty 24 03-02-2016 05:38 PM
Studder/skip in 4wd reverse goneinsixty 1999 to 2016 Super Duty 3 02-11-2015 08:36 AM
Manual Locking Hubs vtdiesel 6.0L Power Stroke Diesel 9 01-05-2005 04:06 PM
Tags
1974, 1978, alberta, building, code, concrete, drive, driveway, f250, ford, highboy, powered, problems, schaumburg, stuck, vbulletin, wheel, wrong
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
