Issue HELP!!!!
Old 04-05-2012, 07:44 PM
Chillman15's Avatar
Chillman15
Chillman15 is offline
Issue HELP!!!!
I just bought a 2010 F150 automatic and need some help. I am going to try to explain this as best I can.
When I take off from a stop my truck jerks once and then is fine. It makes this jerk before it shifts into 2nd.
The best way I can describe it is when you are towing something and take off from a dead stop and the load shifts. That sudden one time jerk is what I am getting all the time.
Does anyone know where I can start looking or checking or has anyone else had this problem?
Anyones help is greatly appreciated.
Old 04-05-2012, 10:04 PM
Speicher's Avatar
Speicher
Speicher is offline
Check out TSB 10-22-6, see if this fits the discription of your symptom. There is a build date cut off, however I have seen this TSB correct a concern even after this cutoff date.
Old 04-06-2012, 04:42 AM
Chillman15's Avatar
Chillman15
IS this as easy as taking the truck to a fold dealership and asking them to check out TSB's for my truck? I am new to this world so please bear with me.
I bought the truck off ebay from a BMW dealership in NJ. I live in cicninnati OH so I would have to find a local dealership I trust.
I am not sure I fully understand how these TSB's work. Is this the same as a recall and the dealerships do this for free or is this going to cost me money from the dealership?
Old 04-06-2012, 05:22 AM
shotgunz's Avatar
shotgunz
shotgunz is offline
If there is any warranty (3 yr/36k miles) left on the vehicle (or if you purchased an ESP) and the TSB applies, then the dealer should perform the TSB for free. If there isn't any warranty left, then you might have to pay to have the TSB work performed.
However, the safest way to get a TSB done is to accurately describe (and demonstrate) the TSB symptoms. If you simply walk-in and tell the dealer SM "I want TSB XX done, you might get refused."
Here's a list of TSBs: https://www.ford-trucks.com/tsb/fulltext/index.php
Old 04-06-2012, 05:37 AM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,218 Likes on 801 Posts
This sounds like the "slip yoke" bump issue that has been going around here for a while. There is a TSB and it requires the dealer to clean and repack the spline on the slip yoke. One fella here is getting anew driveshaft.
A dealer tech will have to drive it but they should know exactly what the issue is right away. This is a driveline issue and should be covered for 5yr / 60K miles.
Old 04-06-2012, 06:33 AM
shotgunz's Avatar
shotgunz
shotgunz is offline
I completely forgot about the 5 yr/60k mile powertrain warranty.
Thanks Tim!
Old 04-06-2012, 09:19 AM
Fire Rooster's Avatar
Fire Rooster
Fire Rooster is offline
I agree with Tim. Sounds like the slip yoke issue. The SD's did it too in the early 2000's
Old 04-06-2012, 08:18 PM
juneau76's Avatar
juneau76
juneau76 is offline
Originally Posted by tseekins
A dealer tech will have to drive it...
^^What they said. The tech needs to drive it and have it happen while he's in the truck. If it doesn't happen during his joyride, they won't do anything.
Old 04-09-2012, 01:18 PM
Chillman15's Avatar
Chillman15
Thanks everyone! I went to the dealership and bought all the parts. Going to do the work myself this saturday.
I don't know what it is but I like doing the work myself on these small jobs. At least this way I know nothing was over looked.
I will let everyone know if this fixed my issue!
Old 04-21-2012, 02:09 PM
Chillman15's Avatar
Chillman15
Just wanted to let everyone know that this fixed my issue. It was completely bone dry and ended up using marine grease and not the ford grease.
Thank you everyone for your help.
Old 04-21-2012, 04:12 PM
D8chumley's Avatar
D8chumley
D8chumley is offline
Resident smarta$$
Just curious as to what parts you bought exactly? I don't have the issue but for my general information is all. It wasn't as easy as removing the slip yoke and re-packing it with grease? Thats all I did on my SD
Old 04-25-2012, 12:21 PM
Chillman15's Avatar
Chillman15
The only item I bought from Ford was the clap that you can find on TSB 10-22-6. I was able to reuse the boot and the upper clamp since I never removed these two. I personally went with Marine Grease and not the ford PTFE Just because I think it will handle the wear and tear better. (Really a personal preference)
So to sum it up, one clamp from Ford and Marine Grease for local auto store.
PART NUMBER PART NAME
9L3Z-3B478-A Clamp (2 Req.)
Old 04-25-2012, 06:17 PM
Pool Runner's Avatar
Pool Runner
Pool Runner is offline
Did it work? I took my truck back twice initially, each time it was greased the bump/ slip in the yoke would come back after 1500-2000 miles. Third time I took the truck in they replaced my entire driveshaft. Truck now feels and drives better than it did with 20 miles on it. Let us know how you're truck turns out
Old 04-25-2012, 06:51 PM
Chillman15's Avatar
Chillman15
As of right now the bump/slip is gone. I only have about 800 miles since the fix but no problems. I will let everyone know if it comes back!
Lets pray that it doesn't! haha
RM2738
6.4L Power Stroke Diesel
12-12-2011 07:58 AM
CarbonClear
07-24-2009 10:46 AM
MotoraceD
Car/truck Buying Advice
04-20-2004 11:20 AM
paradox0430
2004 - 2008 F150
01-23-2004 08:14 AM
slayerboy
1983 - 2012 Ranger & B-Series
01-30-2003 06:52 PM
Quick Reply: Issue HELP!!!!
