2001 f150 2wd 4.2 tranmission problems please help. dtc p0741, p1744 - Ford Truck Enthusiasts Forums
Old 04-05-2012, 04:57 PM
loleuiha's Avatar
loleuiha loleuiha is offline
loleuiha is starting off with a positive reputation.
Hello I been stumped with this problem on my F150 Im trying to sell it but want to get this problem fixed 1st.
When cold the transmission shifts fine through all gears and even applies tcc. But say I drive it from San Jose To S.F. It will be fine. But after that if I dont let it cool down at least 2 hours thats when the problem shows up.
problem: When at Normal Operating Tempurature and having been driven a while. The transmission will slip in and out of 4th to OD. If I depress the AP at any cruising speed it will cycle in and out of OD. Untill I ease off the AP.
DTC: p0741 Torque Converter Clutch System stuck off
DTC: p1744 TCC System Perform.
I have replaced The TCC Solenoid and its still doing it but with no codes.
Im trying to fix this problem as cheap as possible so I can sell it.
All your input would be Greatly Appreciated
Thank you
Laki
Old 04-05-2012, 05:54 PM
Papa Tiger's Avatar
Papa Tiger Papa Tiger is online now
Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.
Understanding you have drained, flushed and replaced the filter, whats left. Disconnect the battery and reconnect after 15 minutes. Run the re-learn sequences and see if it works. You put in new parts. If it doesn't, figure on a torque converter replacement/ tranny reman.
Torque converter clutch solenoid? Mikey_23_ny1 1968-2013 Full Size Vans 6 11-04-2016 10:27 PM
P0743 & P1744 Codes mrc00l88 Excursion - King of SUVs 3 07-04-2016 10:20 PM
1997 Ranger 4R44E Transmission noise ricer333 Clutch, Transmission, Differential, Axle & Transfer Case 0 01-01-2013 07:06 PM
02 EXPY DTC P0741 and P1744 bigdawg7299 1997-2006 Expedition & Navigator 0 09-29-2012 10:02 PM
E4OD mystery: no TCC lockup, no OD light, no codes elskeptico Clutch, Transmission, Differential, Axle & Transfer Case 5 04-21-2012 04:14 PM
Tags
07, 150, 2001, 2003, 2wd, 42, conveter, f150, ford, issue, issues, p0741, p1744, problems, sport, torque, tranmission, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
