Trans problem... E4OD
Finally got my 4x4 E4OD trans and tcase installed in my truck.
Problem is that everything works except Reverse. Fluid is full, brand new shifter cable, goes forward fine, shifts fine, t-case works, but Reverse acts like neutral.
Any ideas? I think I read somewhere that if the trans filter drops down out of place it can cause this problem, but what to know what you all think before I drain it all out again and drop the pan...
Good idea on the filter Evan. Luckily that pan is from the 4R and has the drain plug... just get a clean bucket to drain it into so you can re-use the fluid. Did you have the pan off or did you just do a fluid swap? Knowing what the truck went through it may have been enough to knock the filter loose...
If I am remembering correctly you have to engage the band for reverse to work... If you drop the pan check the piston and rod for the band and make sure it's in place correctly.
You should be able to actuate each gear using an air nozzle with rubber tip... the tranny rebuilder guide will tell you where to blow...
Richard
Richard
I talked to a friend who owns a shop up here and he mentioned something about a snap ring holding the reverse drum in, and thought it was very likely that snap ring broke. Does that seem plausible?
Mark I PM'ed you about this on another site, I'm the one that sold Evan this transmission.
It is normal to have fuzz on the magnet on the automatics...
Richard
This trans is supposed to have 20k on it. When I had the pan dropped on my 2wd trans at 20k there was hardly any fuzz at all.
Whatever is causing me to not have reverse is beyond what I can fix myself. And if I'm taking it in and having a shop tear into it I might as well rebuild it with better parts. Looking at the Racer X website right now, thinking valve body, triple disc converter, and Red Eagle extra clutch packs.
But get everything else from them.
Richard
