Help Draining my Water Separator - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis SPONSORED BY:
Old 04-05-2012, 12:16 PM
ccrider1116 ccrider1116 is offline
ccrider1116 is starting off with a positive reputation.
So before I post this, I have a feeling this is going to be a pretty easy process, so I kind of feel dumb even posting it. BUT, I need to know since I am new to having a diesel. I have read and been told that I need to drain my water separator, and I am unable to get to my owners manual at this time to see what it says. So, how do I drain the water separator and how frequently should I do it?
Old 04-05-2012, 12:49 PM
chi6488 chi6488 is offline
chi6488 is starting off with a positive reputation.
I do mine monthly. Under the driver side of the vehicle you will see the housing with a lever.
I drain for a 30 count and into a glass jar I can inspect and then pour it into a jug for oil changes disposal. If you are on incline might want to back truck in, rear high and drain. I had problems with a moderatly sloped driveway draining until it was too late
Old 04-05-2012, 02:27 PM
Thanks chi! I will do that today. I am not sure if the previous owner of the truck did any of this maintenance so I'm trying to figure out everything I need to do in regards to maintenance. I appreciate the info and if you have any other maintenance related things you do or think I need to check, (other than the standard oil changes/fuel filter changes) I am open ears.
Old 04-05-2012, 02:54 PM
Gearitis Gearitis is online now
Gearitis is gaining momentum as a positive member of FTE.Gearitis is gaining momentum as a positive member of FTE.
If you are not sure what the previous owner has done, I would just bite the bullet and change both fuel filters and change the oil before anything. Check the radiator fluid, fuel cooler fluid, and etc. I can guarantee you that you will not be sorry and feel better that you know you did this.
Old 04-05-2012, 08:40 PM
F250Snowman F250Snowman is offline
F250Snowman is starting off with a positive reputation.
Quote:
Took me a few minutes to find it but once I did the drain took less than a minute. If I can do it anyone can...
Old 04-08-2012, 08:14 AM
weyland426's Avatar
weyland426 weyland426 is offline
weyland426 has a very good reputation on FTE.weyland426 has a very good reputation on FTE.weyland426 has a very good reputation on FTE.
now that you've found the separator, how do like that super convenient and easy-to-get-to location...*extreme sarcasm*?
Old 04-08-2012, 08:37 AM
Finz250 Finz250 is offline
Finz250 is starting off with a positive reputation.
So after you drain it - what then? I drained about 6oz of fuel out and I guess it was just fuel. Since water is insoluble in diesel fuel I would assume any water would be separated or beaded up. But how do you tell?
Old 04-08-2012, 08:40 AM
weyland426's Avatar
pray the warning message goes off forget about it for another month or so i often times only have a drop or two of water in several ounces of fuel...must be one damn sensative sensor.
Old 04-09-2012, 10:42 PM
RM2738's Avatar
RM2738 RM2738 is offline
RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.
Quote:
Either you don't have any water in your fuel or the water has made it through the system. You'd see the droplets if there was any water.
Old 04-10-2012, 11:00 PM
pugster pugster is offline
pugster is starting off with a positive reputation.
I'm draining my water seperator daily now.
Getting tired of it. I drain it, message disappears, drive to work & on way back home I get the message again. I changed both fuel filters last Friday hoping that would help.
I welcome any suggestions, I hate to take it to the dealer or shop where they'll punish me by charging for 2 new fuel filters.
Old 04-11-2012, 12:33 AM
UGA33's Avatar
UGA33 UGA33 is online now
UGA33 is a splendid one to beholdUGA33 is a splendid one to beholdUGA33 is a splendid one to beholdUGA33 is a splendid one to beholdUGA33 is a splendid one to beholdUGA33 is a splendid one to beholdUGA33 is a splendid one to beholdUGA33 is a splendid one to behold
Take the pump off and take the front manifold off and clean the seperator area with carb cleaner. Pull the sensor out of the side of the pump and clean it also.
Old 04-11-2012, 08:24 AM
SeaPig's Avatar
SeaPig SeaPig is offline
SeaPig is starting off with a positive reputation.
Holy Cow!
That is a great Idea.
I never thought of the H2O maybe staying there.
I had this problem a couple of years ago, and it kind of faded away.
I figured it was because I changed where I was getting my Diesel??
~Mike~
Old 04-24-2012, 02:50 PM
UPDATE: So I didn't get a chance to update how this went when I did it, so sorry for the delayed update. I drained the water and filled an 8 oz glass almost 3/4 full of water with just a few droplets of fuel mixed in. Everything I have read tells me that that is too much water. Could it be that the previous owner never did this? I have not gotten any warning messages inside the truck regarding this. I also showed it to my neighbor to make sure I wasn't losing my mind and I wasn't looking at fuel rather than water.
Old 04-24-2012, 03:22 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Have you pulled the filters? Better do that and inspect the fuel bowl for rust and metal.
Old 04-24-2012, 03:39 PM
RM2738's Avatar
I'd also consider draining it more until you drain more fuel than water.
Water in fuel already drained keeps coming back ssoulis 1999 - 2003 7.3L Power Stroke Diesel 13 01-11-2016 10:48 AM
How to drain water from fuel/water separator in a 7.3 PSD van? SweetBearCub 1968-2013 Full Size Vans 1 08-07-2015 02:17 AM
Draining Water Separator marspec 6.4L Power Stroke Diesel 48 02-12-2012 12:05 PM
Fuel water separator draining p12483 6.7L Power Stroke Diesel 43 09-21-2011 11:55 PM
Draining Water Separator..Info Please fairhaven 6.4L Power Stroke Diesel 7 04-26-2009 05:58 PM
Tags
2009, drain, engine, f250, f350, ford, fuelwater, internet, job, power, powered, reduced, search, separator, seperator, truck, vbulletin, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
