02 f 250 parts
Category: Accessories
Price: $1
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): NSX
Item Condition: FL
Engine: Part suitable for gas truck
ok sorry for the delayed response i have been working all weekend on the ring and pinion and rear wheel bearings. The rear spring code is "A".
I do have the front plate bracket and bolts on the truck. never used it. it has some splashing from mud on it and some sun fading i'm sure. are you interested?
added pics of brake lines. Added pics of Dana 60 reverse ring and pinion 3.73 gear ratio. OEM 150 or best offer. Added pics of sterling 10.5 ring and pinion 3.73 gear ratio. OEM 150 or best offer. Added pic of sterling rear differential cover. 50 or best offer.
4wd manual locking hubs. one is good. one was stiff but still works.
100 or best offer.
Ford 2002 f 250 front hub. used. good condition. 75 or best offer. includes needle bearings and abs pigtail. will include two more studs that attach to spindle.
2002 stock air box
do you still have the air intake, if so can you send me pics phatf250wil@yahoo.com thanks
#28
