1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Too complex for me :)
Old 04-05-2012, 09:45 AM
jdadamsjr's Avatar
jdadamsjr
jdadamsjr is offline
Ok - what did I do ?!?
2012 f250 CC
Playing with the 'dimmer' switch and not sure how to get it back...
my dash lites are dimmed too much during the day, but if I go back up with the dimmer switch it turns on the overheads ?!?
does this thing have some multi mode that if the lights are on and you play it does one thing and if they are not it does another ?!?
Old 04-05-2012, 10:35 AM
lllateralus's Avatar
lllateralus
lllateralus is offline
On my older truck, the dimmer switch is also the dome light switch.
If I roll the switch ALL the way UP, it "clicks" and turns on the dome lights.
If I just click the switch back down, the dome lights go off... and if I turn it MORE in the down direction, my gauges start dimming.
Old 04-05-2012, 10:58 AM
kmonty2's Avatar
kmonty2
kmonty2 is offline
Turn the overhead lights on then just tap the button down and the lights should go off but keep the dash lights bright. Also are your head lights on? In auto mode don't cover the sensor in the middle of the dash by the windshield.
Old 04-05-2012, 12:04 PM
edjunior's Avatar
edjunior
edjunior is offline
From page 90 of the owners manual (https://owner.ford.com/servlet/Conte...nerGuidePage):
PANEL DIMMER CONTROL
Use to adjust the brightness of the
instrument panel and all applicable
lit components in the vehicle during
headlamp and parking lamp
operation.
• Tap the top or bottom of the
control to brighten/dim all interior
lit components incrementally, or
• Press and hold at the first
position the top or bottom of the
control until the desired lighting level is reached.
• Press and hold the top of the control to the full on position to activate
the “dome on” feature. This will turn on the interior courtesy lights.
The lights will remain on until the bottom of the control is pressed.
Old 04-05-2012, 07:09 PM
jdadamsjr's Avatar
jdadamsjr
Aha !
thanks !
so i just need to roll it "up" until the overheads come on and then tap the bottom a bit !
Thanks !
Now onto the next tech question for the ages
Raptorgabe
6.7L Power Stroke Diesel
06-16-2014 08:00 PM
dylanellis
21
12-05-2011 07:47 PM
johnp27
2009 - 2014 F150
05-20-2009 09:51 PM
BigRedEX
08-12-2006 08:04 AM
walkpast
07-20-2004 05:21 PM
Quick Reply: Too complex for me :)
