6-speed transmission not shifting properly - Ford Truck Enthusiasts Forums
Old 04-05-2012, 07:45 AM
tuscany tuscany is offline
tuscany is starting off with a positive reputation.
In my 2011 F-250, 6.7, auto....it seems that at certain times went the tranny shifts from 2nd to 3rd and I pause with acceleration, for some reason the tranny seems to go into a slip mode and then slams into 3rd. Now I read about 8 months ago that there was a computer upgrade via Ford. Which they did when I was having some work done on the truck at the dealership......but that didn't help. Just want to see if anyone else has this problem.
Old 04-05-2012, 09:44 AM
whiteywhip's Avatar
whiteywhip whiteywhip is online now
whiteywhip is gaining momentum as a positive member of FTE.whiteywhip is gaining momentum as a positive member of FTE.
SO FAR SO GOOD
Old 04-14-2012, 12:54 PM
Poletech's Avatar
Poletech Poletech is offline
Poletech is starting off with a positive reputation.
Yes I am having the same problem. I can pretty much make the truck do it 99.9% of time. I plan on taking mine in as soon as I can get a break from work.
Old 04-14-2012, 02:51 PM
Tethergrain's Avatar
Tethergrain Tethergrain is offline
Tethergrain is starting off with a positive reputation.
yup me too 9F550 2011)
I posted earlier about this, happened to me 3 weeks ago, stealership resynched servos? told me to drive it as normal, it will relearn. Well, its still stupid, so today it thru an engine code: P0401 EGR crap, naturally, not cvrd under powertrain, for my bumper to bumper has long since passed. Truck is a rolling problem.
Old 04-14-2012, 04:32 PM
Smoke2008 Smoke2008 is offline
Smoke2008 is starting off with a positive reputation.
Transmission Issues somewhat common.....I had to fight with Ford to get my transmission resolved.....There are TSB's out for resolving the transmission issues...but it's almost like pulling teeth ...trying to get Ford to O.K. the repair.
1st TSB 11-7-10, has to do with Transmission shift solenoids 4 of them....and reprogram transmission, this didnot resolve my transmission shifting issue.
Ford approved the replacing of the Transmission valve body which resolved the transmission shifting issue........this was only done after getting video of the shifing flares.....alot of video....and spending almost $ 800.00 on a rental truck to work out of while my truck was in the shop. Please keep in mind this was not a easy process to get Ford to fix something ......and the dealership told me more than once that it was a relearing process....Good Luck give them HE!! and keep us informed....
Old 04-14-2012, 05:01 PM
Quote:
2 weeks ago a friend with a KR .....I think this issue came up with his truck.....there are 6 sensors that have to do with the EGR.......the repair was about $ 225.00 this was a dealer doing the repair...part was $ 85.00 and the rest was labor...
Old 04-15-2012, 07:20 PM
Poletech's Avatar
Hearing stuff like this scares me. I've been a Chevy man for as long as I can remember, and have never had any problems with my local GM dealers covering repairs, or at least working with me. This is my first new Ford truck, and hope that this isnt the beginning of problems........
Old 04-16-2012, 06:50 AM
Barrie guy Barrie guy is offline
Barrie guy is starting off with a positive reputation.
I have had the same problems with my 6.7 2011 F350DRW. I love the truck but the transmission has shifting problems. It shutters going up from 3rd to 4th and 5th to 6th when I have a load on it and hits hard when it comes back down, with ten thousand miles on it. The dealerhip has been excellent so far including sending out a mechanic on his day off to meet me on the Highway with his scan tools while my trailer ws hooked up. It looks like the torque converter is failing according to the computer he hooked up. In a few weeks when I have time to get the truck into the shop I will update this thread with the outcome.
Old 05-18-2012, 10:17 PM
VolDiesel VolDiesel is offline
VolDiesel is starting off with a positive reputation.
I have a 2011 F-250 6.7 with the auto Tran. I have experienced the problem multiple times if I feather the throttle than it almost automatically shifts hard especially 3-4 and 4-5. I thought it was my driving but it may not be.
Old 05-18-2012, 11:38 PM
2ndStroke's Avatar
2ndStroke 2ndStroke is offline
2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation
Same thing here, my truck clunks into 3rd gear, does other werid shifts 5-6, 6-5. Been to the dealer 2 times with no fix. 3rd trip is soon, 5 hour drive to the dealer...nice.
Old 05-19-2012, 08:00 AM
SandR's Avatar
SandR SandR is offline
SandR is gaining momentum as a positive member of FTE.SandR is gaining momentum as a positive member of FTE.
If I take it easy accelerating after shifting to 2nd there is a drop in RPM's and then it shifts to 3rd and then it does it again before shifting to 4th (do not notice this any other time). FordMoCo, not dealer, has told me that this is normal and that it is the torq converter. If I accelerate harder I do not feel it. The shifts are smooth but the RPM drop between shifts is noticeable if taking it easy. It is a '12 f350.
Old 02-08-2013, 12:49 PM
jdeerel jdeerel is offline
jdeerel is starting off with a positive reputation.
2011 F250 2nd to 3rd shifting hard.
My 2011 f250 (gas) does the same thing going from 2nd to 3rd. I took it to the dealer and they did all the TSB testing. Then told me they needed to replace a couple of tranny solenoids. That fixed it for about a week or two then it start to bang into 3rd again. I noticed if I backed out of a space first then went forward it would not bang. Also it seemed to only happen when I let the truck sit for 2 hours or so. I wonder if a 2012 tranny will fit a 2011 truck I don't see any postings for 2012s with this problem....so they know what the root cause is.
Old 02-08-2013, 01:07 PM
audimotion's Avatar
audimotion audimotion is offline
audimotion is starting off with a positive reputation.
^ I have a 2012 and does bad shifts constantly. It had a tranny reflash last fall and all was good for about 1 week, then it started the same crap again.
It will bang into lower gears (sometimes) and when feathering the throttle (around town driving) the tranny is always in a gear too low and then jerks into the next gear. VERY annoying. So annoying, I switch to manual mode when driving in town. That way it doesnt shift to first when going around corners/slowing down and I can regulate shifts. I'm near 40K miles, so I'm just living with it, cause I'm sure ford would say it is only covered under the bumper to bumper coverage...
Old 02-08-2013, 01:22 PM
Rod Bensken Rod Bensken is offline
Rod Bensken is starting off with a positive reputation.
I had this problem with my 2011. They dropped the tranny and replace some pumps, under warrenty. Smooth as a baby's butt now.
Old 02-08-2013, 02:26 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Quote:
I've been dealing with the same issue for over a year now. Latest round was just before Christmas when they had the truck for over two weeks. Replaced the valve body, solenoids, seals, screen / filter, fluid, additive, and reflashed it. It was great for about two weeks and started being a choppy slop box again. Shift flares between 2nd and 3rd and 4th and 5th. In 3rd, it'll go for a few seconds after shifting, lurch like it's trying to shift again, stay in 3rd, and continue on until it actually does shift into 4th.
The other night, my family and I had just pulled onto the road from a parking lot and when the truck began to shift into 3rd, the whole truck just shut down. It felt like somebody stood on the brakes and the engine lost all power. It lasted about 2 seconds and then restarted, shifted into 3rd, and moved right on down the road. I know I didn't hit the brake because I still had my foot on the accelerator and I never drive two-footed. And my foot isn't wide enough to hit both pedals at the same time.
It's back in the shop now. Ford sent a field engineer to check it out so she rode with me and the dealership's diesel and transmission techs. The truck did the same thing with the shift flares and lurching but it didn't die like it did the other night. Because we couldn't "reproduce" the same issue I had the other night, nothing was done and the engineer, Ford, and the techs are saying that these shift flares, lurching, etc. are all just characteristics of this transmission.
They had the laptop hooked up the the truck throughout the time we were driving it which lasted about 25 miles and about an hour's time. They said the truck didn't throw any codes nor did it have any codes stored.
The Customer Service Rep form Ford told me today that since these are normal characteristics of this transmission, the Engineering Hotline has declined to authorize any more work on it. The truck has 10,732 miles on it and besides the 3/36 warranty, it's also got the 72/100K Premium Care ESP.
The only thing I know to do at this point is drive it until it breaks and/or lays down. I do know I won't let my wife drive it because I'd rather not have to worry about her breaking down and being stranded.
As things stand now, if they don't do something, I see a Ram or GM in my future.
2011 f150 6 spd elc trn hard shift 1st-2nd f150 silver bullet 2009 - 2014 F150 7 04-27-2015 10:48 AM
95 f250 7.3 deisel won't shift from 2nd to 3rd manram 1987 - 1996 F150 & Larger F-Series Trucks 13 02-05-2015 04:35 PM
Trans shifting hard could it be the governor? scrobbie 1987 - 1996 F150 & Larger F-Series Trucks 4 01-18-2014 07:12 PM
TorqShift not shifting when cold - this normal? SirHailstone 1999 to 2016 Super Duty 10 01-05-2010 09:05 PM
99 F150xl Surge, Shake & Shutter Tripper Modular V8 (4.6L, 5.4L) 2 12-09-2003 12:30 AM
Tags
03, 2008, 2011, 3rd, 6speed, f100, f150, f250, ford, reprogram, shift, shutter, slips, speed, superduty, tranny, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
