92-96 ford towing mirrors - Ford Truck Enthusiasts Forums
Old 04-05-2012, 02:23 AM
Pearson4 Pearson4 is offline
Pearson4 is starting off with a positive reputation.
Does anyone know if they sell a slide out mirror for the 92-96 Ford 2 bolt mount mirrors. I want the actual mirror to slide out like the newer Fords. I have the older chrome style with a slide out bracket on it and I would like to change up to a new style but I don't like the aftermarket tow mirrors that slip over the existing mirror. Any help would be appreciated. Thanks
Old 04-05-2012, 02:47 AM
882tank's Avatar
882tank 882tank is offline
882tank is starting off with a positive reputation.
No dice. The ones you have are the only ones your going to find besides a slip on towing mirror. Enjoy what you have, they are the best looking ones anyway.
Old 04-14-2012, 02:00 AM
Thanks for the reply. I will keep the ones I got.
Old 04-14-2012, 09:54 AM
turnkyle turnkyle is offline
turnkyle is starting off with a positive reputation.
I've seen guys modify the newer dodge flip up mirrors to fit these trucks but you have to eliminate the triangle window. I like my triangle window to much to do that.
Old 04-14-2012, 10:31 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Someone makes a slider for the western style mirror, if that is what you are talking about. This style. And here is a link http://www.extendamirror.com/
Old 04-14-2012, 12:26 PM
Jaime74656's Avatar
Jaime74656 Jaime74656 is offline
Jim
Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.
I also am wanting to grab a set of tow mirrors but im not wanting the ones that bolt on the doors but im not really sure what is out there honestly, I know LMC has some that just slip over the existing mirrors (XLT trim).
Old 04-14-2012, 09:18 PM
Quote:
What do you mean by xlt trim. 3 mirrors were available no matter what trim level
Old 04-15-2012, 03:11 PM
I have the chrome swing away mirrors on my truck now. The ones with the triangle mount. They already have a plastic slide out adapter on them which works but I have to replace it every year because it cracks and rusts the screws. I would like to get a slide out pair of the smaller plastic two bolt mount type mirrors. I want them to slide out like the newer trucks. I don't want to have to carry a set of mirror extensions around when I need my mirrors wider. I have looked everywhere and can't find any. I thought this would be a good place to look but these mirros might not be available and I definately don't want to lose my vent windows.
Old 04-15-2012, 06:08 PM
Nobody makes a slide out for the "nemo" mirrors. The only thing you can get for them is the slide on extensions that get tightened with a wing nut.
You can use a Dodge mirror though if you dont mind drilling. They go right in the very front corner of the wing window. You can still use your wing.
There is a couple problems with them though.
1. they are a dodge item.
2. they dont slide out, they fold out
3. the passenger one is severely blocked when folded IN
Some pics New Tow Mirrors - PowerStrokeNation : Ford Powerstroke Diesel Forum
This guy went the "easy route" and just drilled holes
This guy took the harder route and welded a pice of metal in
NOCOVY
Page 18 http://powerstrokenation.com/forums/...irrors&page=18
And page 24 Who is interested in a new mirror option for our OBS trucks? - Page 24 - PowerStrokeNation : Ford Powerstroke Diesel Forum
I am probably going to go with the weld in bracket design when I convert my truck to a dually. My mirrors will always be "up" since it is a dually
Super duty mirrors on 92-96 body style? TractorMaster96 1987 - 1996 F150 & Larger F-Series Trucks 15 10-25-2016 01:32 PM
Mirror swap question 92-96 mirrors TylerJ150 1973 - 1979 F-100 & Larger F-Series Trucks 15 10-16-2013 05:06 PM
92-96 Bronco/F-150 RH Power mirror chrome NOS bareaneye WTB - Parts & other 0 05-22-2013 11:56 PM
mirror choices frostysdriver Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 01-18-2010 05:56 PM
mirror conversion? 82 to 92-96 style Timgeorgi 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 02-13-2007 12:16 PM
Tags
1994, 1996, 92, 96, anexpedition, f150, f250, ford, fords, mirror, mirrors, sale, tow, towing, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
