Weird Noise
Old 04-12-2012, 09:43 PM
Will Chiello's Avatar
Will Chiello
Will Chiello is offline
Weird Noise
I have a 1992 F150 4x4 302 5 speed. Whenever I am starting off and letting the clutch out it make a nocking sound. It also makes the noise when you let off the gas after going a good speed and it kind of lunges. It is weird noise and I have checked some things but I cant figure out what it is. Thanks for any help.
Old 04-13-2012, 07:39 AM
blurangkid's Avatar
blurangkid
blurangkid is offline
Check the u-joints for play. I had a similiar problem. Ended up dropping my driveshaft. Check all driveline parts for wear and tightness!
Old 04-13-2012, 01:15 PM
Will Chiello
I changed all my U-joints front shaft and rear. Could it be a motor mount.
Old 04-13-2012, 01:58 PM
blurangkid's Avatar
blurangkid
i changed all my u-joints too before i dropped my driveshaft. The eye on the slip yoke was out-of-round and it snapped! However, I replaced the yoke and thought the problem was solved, but I still kept getting a funny knock. It wasnt until I was plowing one day and started to hear the fan rubbing on the shroud when in reverse. Turns out my motor mounts were completely shot! Replaced them and haven't had any issues since. So yes! It very well could be the motor mounts...Good Luck!
Old 04-15-2012, 05:01 PM
Will Chiello
that was the problem. Thank you for all of the help. the old ones were shot and now it drives so much better.
ksollinger
07-16-2015 02:46 PM
fordtrck302
1978 - 1996 Big Bronco
02-21-2015 11:13 PM
KW160
02-23-2006 10:38 PM
97texan
1997 - 2003 F150
11-21-2004 12:52 PM
4dgirl
05-30-2004 04:51 PM
Quick Reply: Weird Noise
