i have a 1990 f-250 with a 302 efi the problem im having is there is alot of oil and blue hazy smoke going in my air box only wile reving or accelerating i was wondering if any one has had a problem like this or knew what was causing it
When I start my truck up on cold mornings it lets out a big blue puff if I rev it, but it only does it once.
Check and see if your oil smells like gas. you could have a bad ring and it's making it smoke. Does it get worse as you rev it up, or does it kind of clear out as you rev it?
