Next mod, Shift kit!!
I plan on putting in a B&M shift improver kit in the next couple of weeks and was wondering what all i need to do it? obviously i need the kit, a new seal for the pan, a filter, fluid (how much fluid do i need?), anything else im missing? I may add a temperature gauge as well. is there anything else i can upgrade while im in there to extend the life of my transmission?
how about the transgo?
TransGo Performance AODE-HD2 - TransGo Performance Shift Kits - Overview - SummitRacing.com
you can get the b&m kit at most any parts store locally too. once i fix my motormounts ill let ya know how it shifts with the b&m stage 1 kit. right not with broken mounts its BAD lol
but heres a good writeup incluting parts needed and even tools required. took me about 2hrs taking my time to install.
B&M Shift Kit Install on E4OD in 1994 F-150 - Ford Muscle Forums : Ford Muscle Cars Tech Forum
one thing i will recommend tho is to get one of the stay put filter clips. my filter fell out 2days after the kit install.heres a link to the clip. im sure you could find it other places as well.
E40D / 4R100 Stay Put Filter Clip
the bummer about both the E4OD and the 4r70w is they are computer controlled. you can make changes to the valvebody with a shiftkit and see some improvment but the shiftpoints and such still wont change to much. Your advantage is you should be able to get the computer in your truck tuned and the shiftpoints and pressure setup better. its a bit more difficult with the e4od due to the ecu restraints.
is the punisher building 4r70w valvebodys? he would be the guy to go to if so. his e4od valvebodys smoke any store bought kit.
TexasDiesel97
08-08-2009 01:07 PM
93bigbronco
03-06-2002 09:10 AM
