Go Back   Ford Truck Enthusiasts Forums > Misc. > Brakes, Steering, Suspension, Tires, & Wheels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Brakes, Steering, Suspension, Tires, & Wheels Click Here
  #1 (permalink)
Old 04-04-2012, 09:04 PM
dukefan70 dukefan70 is offline
Garage is empty, add now
dukefan70 is starting off with a positive reputation.
Rear brakes won't bleed, front do
'77 F150 4wd 351M V8. Started bleeding my brakes at the right rear, and nothing comes out. Same left rear. A buddy said to try the front ones once or twice and then move back to the rear. Front ones bleed just fine, rear still won't. The person pumping the pedal for me says it feels like a rock when we try to bleed the rear ones.
I'm goin to check to see if I have pressure where the line meets the rubber hose before the rear brakes...thinking the rubber hose may have collapsed. The fitting is being soaked w/ WD40 now. Any other ideas?
  #2 (permalink)
Old 04-05-2012, 06:29 PM
stuart1 stuart1 is offline
stuart1 has a good reputation on FTE.stuart1 has a good reputation on FTE.
You must lift the pin in the proportioning valve.
This one.
Click the image to open in full size.
__________________
Wrench twister since 1957.
Journeyman since 1964.
Transmission builder since 1964.
  #3 (permalink)
Old 04-07-2012, 02:23 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is online now
mikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to all
I think it very possible that you have a collapsed hose. As for the proportioning valve, my diagram shows that it's (or should be) located inside the left (drivers) side frame rail just about below where your feet rest.
You might have to sacrifice the steel line. It's very probable that the flare nut, besides being frozen to the threads, is also frozen solid to the line itself so even if you get the nut to break loose from the threads, the line will just twist with the fitting and break off.
The line really isn't too hard to replace. There is a union in that line about half way up the frame and the lines are relatively cheap.
  #4 (permalink)
Old 04-07-2012, 09:39 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Loosen ALL the bleeders, have someone stab the pedal to the floor and hold it, close the bleeders. Sometimes this will "center" the valve and you can bleed as normal. May take more than one attempt.
__________________
Speed is a question of money. How fast "CAN" you go?
  #5 (permalink)
Old 04-08-2012, 10:29 PM
Alright guys, I guess I'll start simple and work from there. I did find the proportioning valve. I'll try critterf1's suggestion first, and in the meantime I'll look for that union in the brake line. I haven't been looking for it up to now, but I haven't seen one, which with my luck probably means it's behind the gas tank. But I guess we'll find out.
  #6 (permalink)
Old 04-08-2012, 10:45 PM
The pin in the proportioning valve must be pulled out.
__________________
  #7 (permalink)
Old 04-18-2012, 08:49 AM
Did this get repaired or the truck sold?
__________________
  #8 (permalink)
Old 04-18-2012, 07:33 PM
Still a work in progress. I caved and had my buddy (who's actually a mechanic) take a look. New proportioning valve on the way...
Tags
1978, 2003, back, bleed, bleeding, brake, brakes, excursion, f150, fors, front, line, raptor, rear, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
