F250 & F350 why did Ford make them the same? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-04-2012, 08:38 PM
RussF350 RussF350 is offline
RussF350 is starting off with a positive reputation.
From what I understand the F250 & F350 are the same truck with the exception of the blocks in the F350. I have an F350 which I bought because I like knowing I can put lots and lots of weight in the bed (if you're gonna buy a truck you may as well go all the way). So does the F250 really have all the same suspension, springs etc.? Just a different sticker on the door? Why does Ford do this? Makes no sense to me.
Old 04-04-2012, 09:13 PM
jmiley jmiley is offline
jmiley is starting off with a positive reputation.
Quote:
Rear springs and rear blocks are different, other than that, they are the same.
The 350 SRW will ride quite a bit stiffer empty, than a comparable 250.
Old 04-04-2012, 09:33 PM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
Because in many states 10,001 lb vehicles and above are commercial vehicles only. So the sticker has to be different.
Gotta fit inside the law
Sam
Old 04-04-2012, 11:09 PM
Nadster's Avatar
Nadster Nadster is offline
Nadster is starting off with a positive reputation.
The rear axle on the F350 is a little larger and has 37 splines at the hub end. The F250 has 35.
Old 04-04-2012, 11:31 PM
dchamberlain's Avatar
dchamberlain dchamberlain is offline
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
All of the rear end parts on an F-250 and an F-350 SRW are the same, including the main spring pack, with two exceptions. The F-350 has taller blocks, and the F-350 comes standard with the overload spring set above the main spring pack. The axles are identical.
The F-350 DRW uses a different axle, etc.
Old 04-04-2012, 11:45 PM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
Quote:
and this is what separate workhorse from grocery getter.
The note about legal limits is valid as well
Old 04-05-2012, 06:46 AM
Coz77 Coz77 is offline
Coz77 is starting off with a positive reputation.
I was told that getting the Camper Package basically made my 250 a 350 with the extra spring for the camper certification. Don't know if they were blowing smoke or not.
Old 04-05-2012, 09:17 AM
The camper package got you the extra spring (and front and rear sway bars), but not the taller blocks. I don't believe it changed the GAWR or GVWR, but I won't swear to that.
My truck is an F-250 with the extra spring and sway bars and it's GVWR is 8800.
Old 04-05-2012, 10:17 AM
When you speak of blocks are you talking about the blocks for a lift kit? On my 99 with the camper package it came with a factory 2 or 4" lift.
I also ordered the 10000/9900 GVWR package on the new vehicle. It was a $0 option.
Old 04-05-2012, 10:23 AM
The stock blocks between the spring pack and the axle. I didn't know you could order different ones. That's interesting.
Old 04-05-2012, 10:58 AM
TexasRebel's Avatar
TexasRebel TexasRebel is offline
TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.
you can't order different ones... they are specific to the pickup you buy.
F250 4x2 gets no block
F250 4x4 and F350 4x2 get 2" blocks
F350 4x4 gets 4" block
SRW of course. DRW is different.
Old 04-05-2012, 12:52 PM
I understand. Mine was a SRW.
Old 04-05-2012, 04:19 PM
kas83 kas83 is offline
kas83 is starting off with a positive reputation.
Ive seen many early 99 F250 4x4s with 4 inch blocks, all diesels with the engine badge on the fender.....
I'm fairly confident that early 99s all came with the taller blocks, since I remember seeing a TSB about shorter blocks for those pulling 5th wheels.
Old 04-05-2012, 04:46 PM
FordGuy85's Avatar
FordGuy85 FordGuy85 is offline
FordGuy85 is starting off with a positive reputation.
Iv got a early 99 250 with 4.0 blocks in the rear and 3 leaf springs per side up front. I believe it is f350 suspension. When my truck was made, a true f350 had a Dana 60 front axel up front. My truck has the dana 50 up front with a 10.5 rearend out back. Oh also there are 6 springs per side over the rear axel not counting the over loads underneith them. I believe this is f350 suspension on a f250. Custom ordered by the previous owner. So there are more differences between a f250 and f350.
Old 04-05-2012, 04:48 PM
TexasRebel's Avatar
1999 was an odd duck... the mirrors also don't telescope.
If F250s and F350s are the same truck, why does Ford build both? RV_Tech Fifth Wheel & Gooseneck RV Towing 61 01-17-2017 02:41 AM
F-150 and 37" tires Tepot 2015+ F150 6 05-09-2016 03:50 PM
Frame wheelbase on a f350 is it the same fordf350camper 1957 - 1960 F100 & Larger F-Series Trucks 8 07-24-2015 05:12 AM
2011 F250 vs. F350 Benoit1967 1999 to 2016 Super Duty 26 06-06-2011 05:24 PM
who knows the difference between 350 and 350 front springs ozzy460 1994.5 - 1997 7.3L Power Stroke Diesel 4 03-02-2008 07:45 PM
Tags
100009900, 2012, 350, blocks, camper, f250, f350, ford, gvwr, make, package, rear, size, suspension, trucks, understanding
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
