You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Data Plate Decoder
I have what I believe is a 1962 Ford F-100 Unibody.
I'm trying to find where I can decode the Data Plate that was on the interior of the drivers side door.
It says it was made in Oakville, Ontario, Canada.
The numbers are this.
Serial: 111429A - 6661022L
Trim: 01
Paint: 1RR
Axle Ratio: 4.11.1
Series: F-F100
W.B.: 122
Engine: P-3
Trans: L/D
That's what is stamped on the plate.
Any help would be greatly appreciated.
Thanks.
Sorry no good on Canadian Data, Have the NumberDummy take a look.
__________________
Rob
1962 Ford F100 flat bed 4x4, 223, 4spd.
1962 Ford F100 Unibody with Olds 330 & Jetaway
1944 Ford GPW (Jeep) with 1947-48 Willys L-134
To join the Oregon Chapter, click HERE
I have what I believe is a 1962 Ford F-100 Unibody. I'm trying to find where I can decode the Data Plate that was on the interior of the drivers side door. It says it was made in Oakville, Ontario, Canada.
Ford/Mercury trucks (thru mid-year 1968) that were sold new in Canada only were assembled at the Oakville, Ontario Truck Assembly Plant. Today it assembles Edge's, other Ford/Lincoln vehicles based on the same platform.
Assembled and sold new in Canada only: This had to do with tariffs between the US and Canada at that time. The tariffs were abolished in 1967.
> mercurypickups.com < / Has info for assembled and sold new in Canada Ford & Mercury trucks.
I can decode 1965 Canadian VIN's, Rating Plate codes, because the info is in the 1964/72 Ford Truck Parts Catalog.
But, there is nothing in this catalog for 1964 Canadian trucks, nor is there anything in the 1957/63 Ford Truck Parts Catalog for Canadian trucks.
While 1965 is similar to 1961/64, I'm not going to guess.
The following is EZ to figure out: It's an F100 'Uni" on the 122" wheelbase, has a 9" rear axle with a ratio of 4.11-1. 3 speed Ford light duty manual trans with syncromesh in 2nd & 3rd.
1961/62 F100's came with the 223 1V I-6 as standard equpment, the 292 2V was optional.
btw: I see you deleted a post in another thread inre to this subject. Don't bother looking at FTE's VIN decoders, because they do not decode any Canadian info.
btw, part II: 1966/68 assembled in Canada trucks use the same VIN, Warranty Plate and codes thereon as US trucks.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
Did the Canadian trucks had a different Parts manual than the US Ford manual showing the Canadian Warranty tag breakdown?
__________________
Rob
They had to have, because there are only a few Canadian only body part numbers in the 1964/72 Ford Truck Parts Catalog, and these pertain to 1965/66 only.
There are none in the 1957/63 Ford Truck Parts Catalog. I have a 1953 Canadian only Ford/Mercury Truck Chassis Parts Catalog (I bought it one ebay).
There are prolly more out there available for other years, the trick is, to find them.
__________________
