Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Michigan Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Michigan Chapter Join Chapter, Leader: just another truck
  #1 (permalink)
Old 04-04-2012, 06:19 PM
bigrd1990 bigrd1990 is offline
Garage is empty, add now
bigrd1990 is starting off with a positive reputation.
Looking for some help 7.3 powerstroke
Well Im at my wits end with this truck I've replaced the cps twice and sent my new chip back to see if I had bad tunes and they ended up being fine...on all settings except stock & smoke setting it seems fine or should I say better. I checked the psi on the hpop and thats fine. Only other thing I can think Of is the IDM but those are pricey.....so what I was wondering is if there is someone with a 1994.5-1997 PSD willing to let me swap theres out and put it on mine to see if that's the problem. I am located in warren Let me know guys I would greatly appreciate it.
My truck is a 1997 f250
Thanks,
Joe
  #2 (permalink)
Old 04-04-2012, 07:16 PM
maevans's Avatar
maevans maevans is offline
1999 Ford F-250
maevans is a splendid one to beholdmaevans is a splendid one to beholdmaevans is a splendid one to beholdmaevans is a splendid one to beholdmaevans is a splendid one to beholdmaevans is a splendid one to beholdmaevans is a splendid one to behold
I don't know if it would work Joe, but i have a early 99 IDM you could use to check and see if that is the problem.
  #3 (permalink)
Old 04-04-2012, 07:28 PM
Thanks I am gonna go to the 1994.5-1997 Psd forum and see if it's possible
  #4 (permalink)
Old 04-04-2012, 07:40 PM
From what I read it will work
  #5 (permalink)
Old 04-05-2012, 05:22 AM
maevans's Avatar
1999 Ford F-250
Good.
I can meet you half way - Northline and I-75, you can take it home and try it and see if it will solve the problem.
I should be able to do it today after work, 5:00 - 5:30.
__________________
Mark
Ammo is expensive. Don't expect a warning shot..
  #6 (permalink)
Old 04-05-2012, 08:00 AM
Talyn's Avatar
Talyn Talyn is online now
1994 Ford F-250
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
The IDM's will swap for any 7.3 without issue.
__________________
Talyn (AKA: der Schafen Führer)
1994 F250 XLT 4x4 Standard Cab - T-444E Direct Injection Turbo Diesel, 5 SPD M/T Z/F S5-420, Rosewood 160cc Stage 1's, PHP Tuner, 6637, Short Throw Shift Kit, Valair Kevlar/Ceramic, 140V IDM, T-500, 285/75/16 Cooper Discoverer ATR. Steyr C9-A1.
You can get more with a kind word and a 2x4 than you can with just a kind word.
  #7 (permalink)
Old 04-05-2012, 11:13 AM
Great! I'll pm you my number you can call or txt
Thanks
  #8 (permalink)
Old 04-05-2012, 11:28 AM
I sent a PM
  #9 (permalink)
Old 04-05-2012, 01:01 PM
maevans's Avatar
1999 Ford F-250
Quote:
Thanks William, I appreciate the info.
  #10 (permalink)
Old 04-05-2012, 01:07 PM
maevans's Avatar
1999 Ford F-250
Quote:
Thanks
l left you a phone message with my cell #.
  #11 (permalink)
Old 04-05-2012, 06:02 PM
Still on the hunt for a idm to use borrow if anyone can lend a hand.
Mark I appreciate everything.
  #12 (permalink)
Old 04-05-2012, 10:09 PM
Talyn's Avatar
1994 Ford F-250
I dont' really know what the truck is doing, I have not seen and threads in the OBS forum for your issue, but did you check the MAP sensor?
I'd unplug the map sensor and see how it runs then.
__________________
  #13 (permalink)
Old 04-05-2012, 10:16 PM
Talyn's Avatar
1994 Ford F-250
I see your post over there.
I doubt IDM is your problem.
I'd susspect ICP or IPR problems first.
They are more easy to address.
You can Unplug the ICP and see if that changes anything.
Validating Boost numbers though a scanner is not a surefire way to find if the MAP sensor is working, if you unplug the map sensor, you'll still read boost settings, because the truck will start guessing.
Some trucks guess better than others.
My truck didn't run any better with a bad MAP and it Unplugged, but it stopped smoking the street out when I took off.
ICP is next to fuel bowl on rail, I'd try unplugging that and seeing how it runs.
You can order them from Riffraff diesel if you need a new one, as well as an IPR.
If there is oil in the the ICP sensor plug, its most likely bad.
If your getting bad ICP numbers, you wont be fueling properly.
Same thing if your IPR isn't working right and sticking.
Some questions I seen the guys miss were, how new is your oil?
Have you done any mods besides the chip?
Who's tunes?
__________________
  #14 (permalink)
Old 04-05-2012, 10:37 PM
craftsmangary's Avatar
craftsmangary craftsmangary is offline
1997 Ford F-350
craftsmangary is starting off with a positive reputation.
I'm pretty sure a have a extra IDM, or I can test yours on a good truck.
Shake yours and listen to see if you hear water in it, if you do its junk.
I'm in South Lyon so I'm not that far. PM me if you are interested.
__________________
1997 F350 CCLB 7.3
1994 Ranger SCSB
1986 CC Dually 6.9 ATS Turbo kit
1984 Mark VII Diesel
1956 F100 Big Window
  #15 (permalink)
Old 04-06-2012, 03:55 AM
Thanks guys the only other thing that's done is fuel spring shim but that's set up right I double checked it.
Oil has about 2,000 on it and my tunes are phoenix tunes.
Tags
1999, 444e, 73, bad, cover, davidson, ford, gasket, harley, ipc, map, obs, powerstroke, shorts, sinsor, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
