Clutch will not disengage, need some help!
Hello everyone im new to the site and could really use some information. I own a 1978 f-150 with a 4.9l 300 mated to a np435 with np205 t-case. Just this past week i encountered my first drive train problem ever. I started the truck, depressed the clutch and i cant put it in gear because the clutch is not disengaging. I can shut the truck off, put it in gear, start it, although it kinda wants to lurch forward then let the clutch out and it will take off like normal. However when i try to shift into 2nd, same thing, grinding because of the disengagement problem. My guess is that the clutch fork bent as its old and original? If this is the case, can i remove the fork without dropping the tranny? Any info here would be greatly appropriated.
Thanks,
Jared
Thanks,
Jared
I dont know what else it could be. The clutch still works fine if i start the truck in gear and let it out it takes right off as it should. Something is just preventing it from disengaging. its possible the throw out is stuck because i dont really drive it during the winter months. It just makes me wonder how it worked this weekend fine and then not at all yesterday.
when i was younger i had an extremely heavy foot and i had to change clutches more than most people did oil. this was on a 1979 ford f100 300 6 that i drove like it was a ferrari. my problem was the center of the pressure plate would wear down and my throwout bearing would get stuck in the plate until i shut the truck off, then i could freely change to the 3rd gear and drive it home. i dont know why but as soon as i would turn it off i could change the gear. what always seemed to fix it for me was a new clutch, pressure plate and throwout bearing.
I was thinking worn throw out bearing, but I like the idea of the pressure plate being worn also. I know you don't want to, but it would be best to take it apart and see what's going on in there. There's no sense in guessing and throwing parts at. Get in there and get a good look at it and see what's going on and get ALL the problems the first time. You'll be happier in the long run.
Check the Z-bar bushings on both the frame and engine side, also look at the bushing where the rod attaches at the top of the Z-bar. If those parts are worn out then all the pedal travel goes for taking out the slack. Check eveything you can before pulling the tranny.....but I will say a clutch can be right at the point of going bad for a while and all of a sudden......it goes out..Good luck with it!
