Using VIN to id vehicle options?
Old 05-29-2012, 08:34 AM
quigley513's Avatar
quigley513
quigley513 is offline
Originally Posted by part timing
Is there a website where you can enter your trucks VIN to determine what options it came with?
I assume that we all know about this site which shows every build detail for Ford trucks by VIN:
http://www.etis.ford.com/vehicleRegSelector.do
  #32
Old 05-29-2012, 12:42 PM
444dieselrod's Avatar
444dieselrod
444dieselrod is offline
It won't work on my 96 reg cab, has anyone got it to work on an OBS Ford?
  #33
Old 05-29-2012, 03:01 PM
tstillman's Avatar
tstillman
tstillman is offline
Post
Originally Posted by peter_x
Post the vin and get the attention of NUMBERSDUMMY. According to him the decoders on this site and LMC are junk but he can get you the info.
I just purchased a 2010 F-350 SD and can't find a way to decifer the vin. If Numbersdummy sees this I'd be greatful for the secret hadshake so I know what I bought.
Vin is: 1FTWW3BR8AEA04730
The decoder here claims it's an invalad vin. Thanks for your help.
Tom
  #34
Old 05-29-2012, 03:54 PM
quigley513's Avatar
quigley513
Tom
From the link I posted above:
<table border="0" cellpadding="0" cellspacing="0" width="95%"><tbody><tr><td colspan="2">Primary Features </td> </tr> <tr> <td nowrap="nowrap" width="25%">Build Date:</td> <td> 07.08.2009</td> </tr> <tr> <td nowrap="nowrap" width="25%">Vehicle Line:</td> <td> F250/350/450/550 Super Duty</td> </tr> <tr> <td nowrap="nowrap" width="25%">Body Style:</td> <td> Double Cab (3/4 Door)</td> </tr> <tr> <td nowrap="nowrap" width="25%">Series:</td> <td> 350 Series</td> </tr> <tr> <td nowrap="nowrap" width="25%">Engine:</td> <td> 6.4L Diesel V8 Twin Turbo</td> </tr> <tr> <td nowrap="nowrap" width="25%">Transmission:</td> <td> 5 Speed Auto 5R110W - HI/Torque</td> </tr> <tr> <td nowrap="nowrap" width="25%">Drive:</td> <td> LHD 4WD (PTD)</td> </tr> <tr> <td nowrap="nowrap" width="25%">Axle Ratio:</td> <td> 3.55</td> </tr> <tr> <td nowrap="nowrap" width="25%">Emission:</td> <td> 50 State Emission Requirements</td> </tr> <tr> <td nowrap="nowrap" width="25%">Air Conditioning:</td> <td> Manual Air Conditioning</td> </tr> <tr> <td nowrap="nowrap" width="25%">Paint:</td> <td> Royal Red W/B</td></tr></tbody></table>
  #35
Old 05-29-2012, 03:55 PM
quigley513's Avatar
quigley513
And more:
Medium Stone Interior
Less Front Fenders
Decal-4X4 Less O/Rd Srw Silv Met
Tailgate-Black Handle Centre Latch
With Tailgate Lock
With 8' Styleside Box-Steel
4 Cargo Tie Down Hooks - Inside
With Load Box Edge Protectors
Less Pickup Box Extender
Less Load Box Bedliner
With Base Payload Package
172"/4369MM Wheelbase
XLT
(-) Version Packages
Kentucky Truck Plant Build
Security Lock Group
With Camper Pack
11,500 LB. GVW
Less Appearance Group
Less Exterior Appearance Pack
With Power Equipment Group
Less Memory Package
Feature Content Group 1
Kentucky Truck Plant Build Only
With English Language Label
Owner Hand Book Pack
Brand Owner - Ford
With 2 Ton Mechanical Jack
With Power Front Windows
With Electric Rear Windows
With Privacy Glass
With Sliding Rear Window
Less Overhead Console
Less Floor Mounted Console
Adjustable Accl/Brake Foot Pedals
Front Floor Carpet Mats
With Carpet Floor Covering
I/P Insert - Level 1
Sunvisor - Single Driver W/Strap
With Sunvisor Mirror - Passenger
With Level 3 Door Trim Panel
With Bright Front Grille
Less Exterior Wheel Lip Moulding
Less Lower Body Moulding
Less Side Auxiliary Step
Electrochromic Mirror-Mic/Mgm Com
Dual Sail T'Scp TT Mirrors-Pwr/Htd
With Black Exterior Mirror
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
2nd Row Seat 60/40 (3 P) - Folding
With Driver 6 Way Pwr.Seat Adjuster
With Pass 6 Way Power Seat Adjuster
Trailer Tow Prep Pack
Trailer Tow - Class III Receiver
With Front Towing Hook
Exterior Door Handle - Black
With Central Locking System
With Door Entry Remote Control Unit
With Remote Keyless Entry
Less Sun Roof
Less Tu-Tone Accent Colour
Less Body Tu-Tone Paint
Front Bumper - Steel Chromed
Rear Bumper - Steel Step - Chromed
With Front Licence Plate Bracket
Front air bag - Drvr & Pass
Adjustable'D'Ring-Drivers Seat Belt
Less Passenger Air Bag Deactivation
With Adjustable 'D' Ring Pass Seat
With Frame Mounted Tyre Carrier
With Conventional Spare Wheel
Std Duty Dual Front Shock Absober
With Standard Rear Shock Absorbers
With Single Rear Wheels
18" X 8 Cast Aluminium - Type 1
LT 275/70R18E A/T OWL
With Bright Wheel Hub Cover
Less Engine Idle Shutdown Timer
Less Immersion Heater
With Monobeam Suspension - Narrow
Less Stabilizer Package
Less Attitude/Ride Height Pack
With Standard Duty Front Suspension
With Front Stabilizer Bar
Single Leaf Rear Auxiliary Spring
With Rear Stablizer Bar
Less Rear Axle Package
3.55
Rear Axle Limited Slip Differential
With Catalyst
Less Exhaust Pipe Extension
With 4 Wheel Disc Brake Hydro-Boost
Integrated Brake Control
4 Wheel Anti-Lock Braking System
Less Engine Traction Assist
Normal Fuel Fill
Less Fuel Kit - FIA
Less In-Dash Internet Device-FIA
Less Tracking System - FIA
Less Remote Starter - FIA
Less Transmission Power Take Off
Electric Trans Case And Auto Hubs
Less Skid Plates
With Mid-Ship Fuel Tank
Fuel Cap - Non Locking Green
With Diesel Fuel Capability
With Low Sulfur Diesel Fuel Content
With Steering Damper
With Tilt Steering Wheel
Leat/Red Cont/Audio/Crse/MGM Wheel
With Speed Control
Less Auxiliary Heater
With MPH/KMH Speedometer
Tyre Inflation Monitor
Instrumentation Pack
Less Reverse Proximity Sensor
With Perimeter Anti-Theft
With Safeguard Anti-Theft Sys(Pats)
Heavy Duty Battery
Extra Heavy Duty Alternator
With AM/FM CD Player
With NAAO Radio Frequency
With A/V Jack
Analogue Audio Broadcast
Less Family Entertainment System
With Media Gateway Module
Less Camera
Less Homelink
Less Daytime Running Lamps
With Aero Headlamps
With Front Fog Lamps
Less Roof Marker/Clearance Light
Engine Compartment Light
Tail lamps - Level 1
With High Mounted Stop Lamp
With Automatic Headlamp Control
Spare Accessory Switches-4
Royal Red W/B
Generic Country Group 1
F81A-5310-AHD (6000 LB.)
F81A-5310-AHD (6000 LB.) #2
(+)"USA"
(-)"N"
(-) GVMT Service Administration
(-)"CDN"
(-)"GU"
(-)"BRN"
(-)"BZ"
(-)"IS"
(-)"ATG"
(-)"IL"
(-)"AW"
Less Ultimate Package
Less Fleet
  #36
Old 05-30-2012, 01:08 PM
tstillman's Avatar
tstillman
I can't thank you enough for the info. I found the list of not included items very interesting too.
Thanks agian.
Tom
  #37
Old 02-20-2013, 01:31 PM
spaceblonde's Avatar
spaceblonde
spaceblonde is offline
I am thrilled but only thing I need is bed size and not seeing that
1FTHX26G7PKB97665
Vehicle:
F250 PICKUP SUPER CAB 4X4
Year:
1993
Build Date:
August 6, 1993
Paint Code: DD
Trim Code: FK
Gross Weight: 8,800lbs
Found 26,711 vehicles matching that year and model in our database.
CodeDescriptionF3THBNOT DEFINEDF1TAPNOT DEFINEDF3TAPNOT DEFINEDAAAADXLT VERSIONAAGAJKANSAS CITY PLANT BUILDAALAAWITHOUT SPECIAL EQUIPMENT PACKAGEAAMABCONVENIENCE GROUPABKABPOWER EQUIPMENT GROUPAC0B0MANUAL AIR CONDITIONERBHEABWITH NOISE INSULATION PACKBLDABCHROME-PLATEDBMLAELOWER B/S MLDGBSDAJDRIVER LOW MOUNT BRIGHT MIRRORBSFAKPASS LO-MNT BRIGHT MIR CONVEXBWDABSEAT MATERIAL-REAR CLOTHB3AABWITH RH 2ND ROW FLIP OPEN WINDOWB3CABWITH RH 3RD ROW FIXED WINDOWB3HABWITH MANUAL OPEN REAR WINDOW (FLIP)B3HADSLIDING REAR WINDOWCLVABFRT LICENSE PLATE BRKT/HOLDERC1CAETRAILER TOW HEAVY DUTYDAAADWITH SUPER ENGINE COOLING SYSTEMDWCABWITH HANDLING PACKAGED3JUCLT235/85R-16E BSW A-S TYRESD5AAHWITH SPORT WHEEL COVEREGAMD4.10EGJABNON-LIMITED SLIP REAR AXLEEGLABFORD/VISTEON AXLE VENDOREJAJF6250 LB(2834 KG) REAR AXLE ASYEN0VG7.5L OHV EFI NA V8 GASFMLADMAN TRANS CASE & AUTO HUBSGBCABWITH AUXILIARY FUEL TANKGRAACTILT STEERING WHEELGTDABSPEED CONTROLHTAACHEAVY DUTY BATTERYIBAAGELECT AM/FM/STEREO/CASSETTE/CLOCKJCBABAMBIENT LIGHTING PNDADMOCHA FROSTTR0DE4 SPD AUTO TR-NAAO E4OD(4R100)000DBGREY/BLUE STRIPE
  #38
Old 02-23-2013, 11:58 AM
thechief66's Avatar
thechief66
thechief66 is offline
1FTHX26G7PKB97665
Vehicle:
Year:
1993
Build Date:
August 6, 1993
Paint Code: DD
Trim Code: FK
That truck should be a 155" wheelbase, which is a Supercab long bed.
  #39
Old 02-23-2013, 01:55 PM
spaceblonde
thanks ,, not getting that truck ,, was pulled in to put alternator on and mechanic found oil in coolant so there looking for another 3/4 ton truck
  #40
Old 02-23-2013, 02:55 PM
thechief66's Avatar
thechief66
Could just be a bad oil cooler. In fact thats probably the most likely problem.
  #41
Old 02-23-2013, 07:04 PM
spaceblonde
could be ,, however I live in Fritch TX truck in Rawlings WY ,, and i would have to drive it back!! 700 mile drive is a big gamble ,, any one in wyoming wanting a 4x4 f250 supercab I'll give ya the name of the dealer !!
  #42
Old 02-24-2013, 07:31 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Has to be a long bed. short bed F250 were not offered till 95
  #43
Old 04-01-2016, 04:47 AM
Jimmie Goodman's Avatar
Jimmie Goodman
Jimmie Goodman is offline
Need front-end work
Originally Posted by thechief66
Ford's database for our older trucks is pretty limited, but if you want to post your VIN, I'll see what I can find out for you.
My vin is 1FTHF26H3VED14939 I'm trying to figure out what my front end is so I can replace the upper and lower ball joints please help
  #44
Old 04-01-2016, 12:16 PM
subford's Avatar
subford
subford is offline
1FTHF26H3VED14939:
Build Date: 02.12.1997
Vehicle Line: C346 APA MCA China
Body Style: Single Cab (2 Door)
Version: 350 Series
Engine: 5.8L OHV EFI V8 (NP)
Transmission: 5 Speed Manual
Drive: LHD 4WD (PTD)
Axle Ratio: 4.10
Emission: With 49 State Emission Requirements
Air Conditioning: Manual Air Conditioning
Paint: Oxford White #2
Ruby Red
Styleside Box - STL Inner/Outer
133"/3378MM Wheelbase
(-)"XL"
Less Special Equipment Package
8800 LB. GVW
With Rubber Floor Covering
With Heavy Duty Trailer Towing
Single Cab (2 Door)
With Steel Spare Wheel
LT235/85R-16E BSW A-S Tyres
With Conventional Spare Tyre
With Standard Suspension
With Handling Package
4.10
Less Rear Axle Limited Slip Diff
Heavy Duty Battery
Electronic AM/FM/Stereo With Clock
Oxford White #2
350 Series
5 Speed Manual
C346 APA MCA China
  #45
Old 04-01-2016, 01:50 PM
andym's Avatar
andym
andym is offline
I'll make it easier for you. Your truck either has a Dana 44HD or a Dana 50. They are very easy to tell apart once you know what to look for.
This is a Dana 44 HD. Note how the hub body is much narrower than the opening the wheel sits on. The hub tapers out so the wheel fits:
This is a Dana 50. Note how the wheel opening is just slightly larger than the hub itself.
Quick Reply: Using VIN to id vehicle options?
