Using VIN to id vehicle options?
I did find this site where you can enter your vin to get information on it.
The Ford Truck 17-Digit Vehicle Identification Number (VIN) Decoder
BTW in the maintinence section you can pull up owners manuals as far back as 1996.
Go to this thread. The site is doing maintenance but it is unbelievable the info it will give you
https://www.ford-trucks.com/forums/1...n-decoded.html
If someone can help, I'd appreciate it.
Since 11/2006, I've decoded over 800 VIN's for FTE members, so post the puppy, I will decode it for you, but...
Be aware that the VIN has no trans, rear axle, trim, paint codes and etc within it.
These codes and more are listed separately on the Certification Label (1961/80 Warranty Plate/1948/60 Rating Plate). I can decode this jazz, too.
10 digit VIN = 1948/56 / 11 digit VIN = 1957/80 / 17 digit VIN = 1981 thru today.
Example of a 17 digit VIN: 1FTEF15G3FNA12345
1FT = FoMoCo USA complete vehicle.
E = Class E ~ 6,001-7,000 lbs. GVWR
F15 = F150 2WD Pickup.
G = 351W
3 = Check digit, FoMoCo use only.
F = 1985.
N = Norfolk VA Assembly Plant.
A12345 = 1985 Numerical Sequence of Assembly.
The decode info will be from the 1980/89 or 1990/2001 Ford Light Truck Parts Catalogs. I have no VIN info after 2001.
G = 351W
F = 1985.
1FTNX20P73EC59229
And
1FTNW20P04EA97271
What I am interested in is knowing what options the trucks came out of the factory with (aka the build sheets)
Thanks.
And
1FTNW20P04EA97271
Thanks.
Straight from the site I linked to in my post (#14) above, guys..........
http://www.etis.ford.com/ Click the "VEHICLE" tab, enter your VIN.
1FTNX20P73EC59229
Outstanding Field Service Actions
59B01 - OR 06E17 FOR DETAILS.
06E17 - CONTROL MODULE RECALIBRATION
Primary Features
Build Date: 04.03.2003
Vehicle Line: F250/350/450/550 Super Duty
Body Style: Super Single Cab
Series: 250 Series
Engine: 6.0L OHV Diesel V8
Transmission: 5 Speed Auto 5R110W - HI/Torque
Drive: LHD RWD
Axle Ratio: 3.73
Emission: With 49 State Emission Requirements
Air Conditioning: Manual Air Conditioning
Paint: Arizona Beige
Minor Features
Medium Parchment
Blocker Beam-Underbody Front End
With Tailgate Lock
With 8' Styleside Box-Steel
With Load Box Edge Protectors
158"/4013MM Wheelbase
XLT
(-) Version Packages
Less Special Purpose Vehicle
Less Fleet Related Items
Kentucky Truck Plant Build
U.S. Sales
Security Lock Group
With Camper Pack
8800 LB. GVW
Less Appearance Group
Less Exterior Appearance Pack
With Power Equipment Group
Less Ambient Temp/Speed Pack
Job No.2 Program Control
Kentucky Truck Plant Build Only
With English Language Label
Owner Hand Book Pack
With 2 Ton Mechanical Jack
With Power Front Windows
With Hinged Side Windows
With Privacy Glass
With Sliding Rear Window
Less Overhead Console
Less Floor Mounted Console
Fixed Foot Pedals
Front Floor Carpet Mats
Less Rear Floor Mats
With Carpet Floor Covering
Sunvisor - Single Driver W/Strap
With Sunvisor Mirror - Passenger
With Level 3 Door Trim Panel
Grab Handle Side Door - Plastic
With Sound Insulation Pack Level 1
Less Exterior Sun Visor
With Bright Front Grille
Less Exterior Wheel Lip Moulding
With Lower Body Moulding
Less Rear Window Protector
With Side Auxiliary Step W/O Lights
With Dipping Rear View Mirror
Dual Sail Mtd Power Mirrors
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
With Seat Belt Warning Light
With 2nd Row Bench Seat - 3 Passngr
With Driver 6 Way Pwr.Seat Adjuster
With Pass 2 Way Manual Seat Adjust
Trailer Tow Prep Pack
With Trailer Towing Attachments
With Front Towing Hook
Exterior Door Handle - Black
With Central Locking System
With Door Entry Remote Control Unit
Less Sun Roof
Less Body Tu-Tone Paint
Less Bodyside Accent Stripe
Front Bumper - Steel Chromed
Rear Bumper - Steel Step - Chromed
With Front Licence Plate Bracket
With Fr Seat Integrated Restraints
With Driver Air Bag
With Passenger Air Bag
Adjustable'D'Ring-Drivers Seat Belt
With Passenger Air Bag Deactivation
With Frame Mounted Tyre Carrier
With Steel Spare Wheel
Std Duty Dual Front Shock Absober
With Standard Rear Shock Absorbers
With Single Rear Wheels
7.0 X 16" Chrome Clad Steel Wheel
LT265/75R-16E Owl A-S Tyre
With Conventional Spare Tyre
Less Wheel Covers
With Bright Wheel Hub Cover
Immersion Heater Engine
Less Attitude/Ride Height Pack
With Standard Duty Front Suspension
With Front Stabilizer Bar
With Heavy Duty Rear Springs
With Rear Stablizer Bar
3.73
Rear Axle Limited Slip Differential
Ford Axle Type
Rear Axle/Wheel Lube-Mineral Based
With Twin I Beam Front Axle
Less Catalyst
Less Exhaust Pipe Extension
With 4 Wheel Disc-Brake
4 Wheel Anti-Lock Braking System
Less Transmission Power Take Off
Less Transfer Case
Less Skid Plates
Less Clean Fuel Fleet Vehicle
With Mid-Ship Fuel Tank
For Unleaded Fuel
With Low Sulfur Diesel Fuel Content
Less Steering Damper
With Tilt Steering Wheel
Basic Type Steering Wheel
With Speed Control
Less Auxiliary Heater
With MPH/KMH Speedometer
Less Reverse Proximity Sensor
Less Engine Immobiliser
Heavy Duty Battery
Heavy Duty Alternator
Elect Prem Stro/Cass/Disc/Clock
With NAAO Radio Frequency
Less 4X4 Version Pack
Less Daytime Running Lamps
Less Front Fog Lamps
Less Roof Marker/Clearance Light
Engine Compartment Light
With Dual Beam Dome Map Light
With Glove Box Illumination
With Load Compartment Lamp
Tail lamps - Level 1
With High Mounted Stop Lamp
With Automatic Headlamp Control
Arizona Beige
2C34-5310 WA Left Front Coil Spring
2C34 5310 WA Right Front Coil
Less B&A Control Codes Issue 030388
Less B & A Control Codes (9270)
Less LPO 50S Emiss Calib Label
(+)"USA"
(-)"N"
(-)"CDN"
(-)"AUS"
(-)"GU"
(-)"BRN"
(-)"BZ"
(-)"ATG"
(-)"CHN"
(-)"BO"
Mrkt Comb-SD Airbag Drvr/Pass
1FTNW20P04EA97271
Primary Features
Build Date: 26.09.2003
Body Style: Double Cab (3/4 Door)
Series: 250 Series
Drive: LHD RWD
Axle Ratio: 3.73
Emission: With 49 State/Non Green State Req
Paint: True Blue
Minor Features
Medium Flint
With Tailgate Lock
With 6 3/4' Styleside Steel Box
156"/3962MM Wheelbase
XLT
U.S. Sales
Security Lock Group
With Camper Pack
8800 LB. GVW
Job No.1 To Mid Year Program Ctl
With Electric Rear Windows
With Privacy Glass
With Full Floor Console
Fixed Foot Pedals
Less Side Auxiliary Step
Telecsp TT Pwr Htd Lighted
With Black Exterior Mirror
2nd Row Seat 60/40 (3 P) - Folding
With Driver 2 Way Mnl. Seat Adjust
With Remote Keyless Entry
Less Sun Roof
Rocker Tu-Tone Paint
With Inertia Front Seat Belt
With Driver Air Bag
Less Passenger Air Bag Deactivation
7.0 X 16" Forged Aluminium Wheel
Less Wheel Covers
Less Wheel Nut Covers
Less Stabilizer Package
Less Rear Axle Package
3.73
Ford Axle Type
With Catalyst
Less Transfer Case
Less Skid Plates
With Diesel Fuel Capability
With Speed Control
Instrumentation Pack
Heavy Duty Battery
With AM/FM CD Player
With Front Fog Lamps
True Blue
Lt. Argent/Md. Platinum/Lt. Argent
(+)"USA"
(-)"N"
(-)"CDN"
(-)"AUS"
(-)"GU"
(-)"BRN"
(-)"BZ"
(-)"ATG"
(-)"CHN"
(-)"AW"
1FTNX20P73EC59229
Primary Features
Series: 250 Series
Drive: LHD RWD
Axle Ratio: 3.73
Minor Features
Medium Parchment
With Tailgate Lock
XLT
U.S. Sales
Security Lock Group
With Camper Pack
8800 LB. GVW
With Privacy Glass
Fixed Foot Pedals
Less Sun Roof
With Driver Air Bag
Less Wheel Covers
3.73
Ford Axle Type
Less Catalyst
Less Transfer Case
Less Skid Plates
For Unleaded Fuel
With Speed Control
Heavy Duty Battery
Arizona Beige
(+)"USA"
(-)"N"
(-)"CDN"
(-)"AUS"
(-)"GU"
(-)"BRN"
(-)"BZ"
(-)"ATG"
(-)"CHN"
(-)"BO"
1FTNW20P04EA97271
Primary Features
Series: 250 Series
Drive: LHD RWD
Axle Ratio: 3.73
Paint: True Blue
Minor Features
Medium Flint
With Tailgate Lock
XLT
U.S. Sales
Security Lock Group
With Camper Pack
8800 LB. GVW
With Privacy Glass
Fixed Foot Pedals
Less Sun Roof
With Driver Air Bag
Less Wheel Covers
3.73
Ford Axle Type
With Catalyst
Less Transfer Case
Less Skid Plates
With Speed Control
Heavy Duty Battery
True Blue
(+)"USA"
(-)"N"
(-)"CDN"
(-)"AUS"
(-)"GU"
(-)"BRN"
(-)"BZ"
(-)"ATG"
(-)"CHN"
(-)"AW"
As I am not looking for a VIN decoder SW per se.
Thank you.
E = Class E ~ 6,001-7,000 lbs. Gross Vehicle Weight Rating.
X15 = F150 2WD Super Cab Pickup.
Y = 4.9L (300) I-6.
6 = Check digit, FoMoCo use only.
R = 1994.
K = Kansas City MO Assembly Plant.
A52773 = 1994 Numerical Sequence of Assembly, the trucks specific serial number.
Info source: 1990/2001 Ford Light Truck Parts Catalog (on microfiche) / General Information Section.
#28
The 1987-1996 forum.
For the most part we do not have somebody posting in this forum for information about a 2003.
So I stand by what I said above for this forum:
"There is no VIN decoder that will tell you that.
They will only tell you the information like NumberDummy posted above.
The only way to get that is to email FORD if they still do that and they will mail you a Build Sheet. "
#30
Paint code PL-Tobago Green
(what the heck is a tobago, anyway?)
Interior code C6
Rear axle code S838F conventional 8.8 ring gear
Emissions calibration code 352JR10
Oh, and it was built on 11/11/93
