460 idles fast and cant slow down - Ford Truck Enthusiasts Forums
Old 04-03-2012, 11:40 PM
Ford59galaxie Ford59galaxie is offline
Ford59galaxie is starting off with a positive reputation.
I put a 1977 460 in a 1979 3/4ton and I cannot get this motor to idle down. The facts are I put a early 429 timing chain and gears on this 460 to get away from the retarded timing. I took all of the emission/smog equipment off. There seems to be no vacuum leaks and all ports are capped off. I sprayed wd40 all around this motor checking for leaks and it made no difference in engine run. The only thing leaking is around the bottom of the automatic choke on the intake manifold but this should make no difference because it runs off exhaust. (I now use manual choke) I am using a brand new holley carburetor and have open headers. When you shut the key off the motor diesels itself (keeps turning over). The primary and secondarys in the carburetor close all the way indiacting no vacuum leak. The motor is timed now and the vacuum advance is working although acts weird when you take the vacuum from the distributor the timing will retard itself. Does anybody have any ideas/suggestions I could try?? Thanks
Old 04-03-2012, 11:44 PM
I also forgot to mention that the idle screws are all the way in and wont slow anything down to where it should be running. Throttle is all the way backed off also.
Old 04-03-2012, 11:49 PM
devino246's Avatar
devino246 devino246 is offline
devino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputation
Float levels and idle mixture set correctly? What's your initial timing?
BTW, vacuum going to the distributor is vacuum advance. Removing vacuum from the distributor should retard the timing.
Old 04-03-2012, 11:54 PM
OldStyle's Avatar
OldStyle OldStyle is offline
Rusty Roller
OldStyle has a good reputation on FTE.OldStyle has a good reputation on FTE.
Sounds like you are doing two things wrong. First you time the engine with the vac advance hose removed and plugged off. Second the vac advance hose goes to a ported vacuum source; meaning there is NO vacuum at idle.
The idle mixture screws should start with a basic adjustment of 1 1/2 turns out and the rpm at approx. 650 w the vac adv line off and plugged.
Old 04-03-2012, 11:57 PM
7636074460 7636074460 is offline
7636074460 is gaining momentum as a positive member of FTE.
first thing the reason for the timing change is because you either have the advance line hooked into the manifold itself or the bottom port on that holley(Full Vacuum sources) if want to change that, hook the advance to the upper vacuum port which will only have vacuum when you open the throttle.
you didnt say anything about your idle set screw, is it all the way out???? try turning in the idle mixture screws a 1/4 turn each also. you should be able to turn one side down until the you hear the idle change them come back out a fraction, repeat on the other side
Old 04-04-2012, 12:40 AM
Sorry i forgot to indicate that i currently have the idle screws nearly all the way in. Which in reality the motor shouldnt even run like this. But i did time the motor with the vacuum blocked off. But 1 thing you said that the vacuum should not be running at idle. I currently have the hose running to a bottom port on the holley which DOES give vacuum on idle. It originally ran on a ported vacuum switch but the threads were bad and leaking antifreeze so i ran it directly to the carburetor. You also said that i could run it on an upper carb port to only get vacuum with some throttle? Would this cause it to run rough on idle though? thanks guys
Old 04-04-2012, 12:52 AM
Zigmyster Zigmyster is offline
Zigmyster is starting off with a positive reputation.
Disconnect your throttle linkage at the carb and see if that makes a difference. You said you changed the carb. Possibility that the linkage is keeping it front idling down?
Old 04-04-2012, 12:55 AM
meant.. from idling down..
Old 04-04-2012, 08:34 AM
The throttle is backed all the way off
Old 04-04-2012, 08:55 AM
ChiefM's Avatar
ChiefM ChiefM is online now
ChiefM has a great reputation on FTE.ChiefM has a great reputation on FTE.ChiefM has a great reputation on FTE.ChiefM has a great reputation on FTE.
The dizzy should not have vacume at idle, IT HAS TO BE PORTED.
Old 04-04-2012, 09:33 AM
OldStyle's Avatar
Rusty Roller
Lets start from scratch. Starting with a warm engine. Start the engine and then with the vac advance hose disconnected and plugged.
Disconnect your throttle linkage so that's not an issue; holding the throttle slightly open.
Set your timing to spec. Stop the engine.
Make sure your choke is full open and the fast idle cam IS NOT engaging the adjustment screw.
Turn your idle mixture screws in lightly till they stop then back each one out 1 an 1/2 turns. Start the engine.
If it won't idle turn the idle speed screw in till the arm moves slightly. try starting it again. Repeat till it keeps running.
Adj the idle speed screw till the rpm is near 650. Then you can start adjusting the mixture screws for smooth idle and highest vacuum; lowering the speed accordingly keeping in the 650rpm range. It might take a few back and forth adjustments to get it best.
When you are happy with the carb then reattach the ported vac hose. The engine sound and speed should stay the same. If it changes double check to verify you have NO VAC at idle.
Reconnect the throttle linkage making sure there is free play and it isn't holding the throttle plates open.
The only thing left is to set the choke and fast idle adjustments. You can manually move the choke cam to the higher notch and adj the fast idle speed screw, on the choke side of the carb, to specified rpm, 1200 or so.
Then when cold turn your choke cap to set your cold start position.
Sorry I don't have the specs but we don't know what model Holley you have and I don't have those anyway.
My apologies if I have left anything out; doing this from memory.....
Old 04-04-2012, 09:52 AM
F-250 WARHORSE's Avatar
F-250 WARHORSE F-250 WARHORSE is offline
F-250 WARHORSE is gaining momentum as a positive member of FTE.F-250 WARHORSE is gaining momentum as a positive member of FTE.
I have seen those holleys hold the primaries open by the fast idle adjustment screw. Even if the fast idle is totally off if the screw is too far in then it won't let the primaries close. Have you verified that the primaries are actually closed or are you assuming so because the screw is backed off? If your screw is backed off but the throttle stop isn't hitting the screw then you have a condition to address elsewhere. It sounds to me like your fast idle adjustment screw needs backed off. If your throttle is open far at all on a holley you run in the transition circuit and then the idle screws affect nothing and you get a nasty flat spot off idle. Verify that the throttle plates are actually closed, and hitting stop screw before you go anywhere. With the throttle plates open at all your vaccuum advance is getting vaccuum and you aren't isolating your idle circuits so you will never get it right.
Vacuum advance 101 winginit 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 70 11-10-2016 12:15 AM
Choke questions answered. fmc400 1973 - 1979 F-100 & Larger F-Series Trucks 55 07-30-2014 11:11 AM
Retard or advance to stop dieseling D. DeBoer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 07-12-2014 08:38 PM
Stupid Carburetor Question KsCop 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 12-14-2013 09:29 AM
Things I've Learned About Timing and Idle Speed 1983F1503004x4 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 05-23-2013 01:24 PM
Tags
1976, 351w, 460, adj, advance, backed, fast, ford, high, holley, idle, idles, primarysecondary, screw, timing, vacuum, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
