53 f100 radiator hose metal part
More stock questions as I have some confusion. I got a top radiator hose kit but from Macs and I am having issues with the tubes not being long enough from the radiator to the bend and its like 3" short. I realize it says cars do they make a truck version? Could I use just longer rubber hose? What was the stock setup on the 53?
Here is what is on there now is this factory or a jimmy rig?
That's rigged. Bad news, there are no reproductions. Here was a thread where I asked the same question, and an answer: https://www.ford-trucks.com/forums/1...hose-pipe.html
I tried an exhaust shop, but they could only go down to a 1 1/2" pipe. The flathead radiator pipe is a 1 1/4"
The stock pipe looks like this:
I figured they where rigged. I thought about it and decided to keep the stainless tube and just get longer rubber hose for the short area. Here is a pic of where it sits now
Do they repop the correct length metal hose part in stainless or even straight steel?
I think with the flathead really loosing steam by 53 and it having some 1 year only things it got pushed to the side. It was easy to drop in a y block or fe that made more power and I could see it being more practical in the day for towing to have a y block or fe.
I love my flathead and never want to swap it. I think it makes the truck cooler. Dropiing in a fe or 302 is easy but what is cool about that? Glad your staying with a flathead. I also commented on your t5 thread as I am planning on the same thing.
**Correction: If somebody makes them, I haven't found them yet.**
I've had my truck, with it's original flathead, since I was 15. I don't see a reason to change it now. If it ever grenades, I don't know. But I would probably stick with a flattie.
I may stop by an industrial electrical contractor while I'm out. With the anti-corrosive properties of modern coolant, I don't think longevity would be a problem.
Chappy, I got chrome ones for my 53 from a place called Hot Rod and Custom Supply a few years ago. Their catalog said they fit 49-53 trucks. When I got them they were a little too long. But I shortened them with a pipe cutter and they fit pretty good. Their phone number is 239 574 7744
Found this on the HAMB: hot rod and custom supply? - THE H.A.M.B.
Edit: Called the number, it's an air conditioner repair company now.
I have to agree. When I installed my Offy heads and intake, I also polished the top of the radiator, and painted most of the engine accessories to try to match it. It seemed like a good idea when I was 17, but looking back at it:
For now I am going to keep the stainless shorter pipes and just bought longer top rubber hoses to make up the difference. They only needed to be a foot so just like the bottom length nothing major I will post up a pic when its installed tonight or tomorrow. I would like to find an original set to make a copy in stainless though.
