Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-03-2012, 10:15 PM
J ballan's Avatar
J ballan J ballan is offline
2003 Ford F-150
My Garage
J ballan is starting off with a positive reputation.
OIL PUMPS?
Just wondering if I should use a standard volume oil pump or a high volume oil pump in my lightly modified 400? Thanks
  #2 (permalink)
Old 04-04-2012, 09:55 AM
mark a.'s Avatar
mark a. mark a. is offline
Garage is empty, add now
mark a. has a very good reputation on FTE.mark a. has a very good reputation on FTE.mark a. has a very good reputation on FTE.
Everyone has their reasons & opinions but in nearly 30 years of building 335's the only pump I will ever put in them with the 4x4 pan is a Sealed Power h.v.
__________________
'79 F250 13" lift 42" Super Swampers
  #3 (permalink)
Old 04-04-2012, 05:45 PM
crsmiffy crsmiffy is offline
crsmiffy is starting off with a positive reputation.
yup you are right, splits opinions. My research suggests for non race use to use a standard pump and on a rebuild ensure your clearances are fine-with the possible exception of a HP relief spring to raise oil pressure (not volume). BUT as I have posted on a similiar thread, I wish I had a dollar for every build I've seen/read about/ been told about that had a HV pump fitted. They cant be too bad with the only thing being a potential to shear the dizzy drive pin from the extra load. Mark A. do you do anything different there as I have read that it pays to fit a second roll pin?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
