Time for an overhaul of the brake system: need advice
As stated I am overhauling the entire brake system of my 2007 FX4. I'm going to assume all rotors will have to be replaced and I'm going with ceramic pads.
Here's where I need some help. I have a few problems to adress.
1. Squishy brake petal. I have herd of some home remidys including bending the brake rod? Seems scary to me. Anybody know of some legit ways to make the petal feel like it's a bet more solid?
2. ABS, I do a lot of offroad driving due to work and hunting. Unless I'm crawling along I have issues with the abs being too tender and it causes some hair raising moments when I hit the brakes and get nothing but abs tremor and no actual stopping. Anybody know how to help this? I'm sure there has to be something due to the raptor and it's offroad abilitys. I'd also assume anybody who drives in the snow would have the same issues.
3. Stopping power. Between my 33 inch tires and my 18 foot trailer it seems I could use a bit more power. My brakes have yet to fail me or even get me close but if somebody goes to really screwing up I'd like to be able to have the best chances possible.
Any advice would be beyond helpful. Thanks for reading and thanks for your help.
Air in the lines. Bleed the brakes. And flush the brake fluid if it hasn't been done within the last 2 years
Check very carefully for a worn front wheel bearing. (If the bearing allows the tonal ring to get off center the ABS will think the wheel is not rotating and engage the ABS.)
Large diameter tires (i.e, large radius) gives the wheel more leverage to keep the rotor rotating when you want it to stop. (Think of a breaker bar with a pipe added for more leverage.) A smaller radius wheel/tire will increase your breaking power.
When towing my bass boat my braking actually improves because my trailer has disc brakes. For about $300-$500 you can equip your trailer with brakes. One really cool thing about the coupler actuated system is that when you coast the trailer will not push you and the tendency to come around on you while rolling downhill is reduced.
Smaller tires on your truck will help but you're probably not going to do that.
Good luck.
