85 300 inline 6 carb help, please!!! - Ford Truck Enthusiasts Forums
Old 04-03-2012, 10:28 AM
shaw4825's Avatar
shaw4825 shaw4825 is offline
shaw4825 is starting off with a positive reputation.
I just bought an 85 F150 with the inline 6 and having trouble with the carb. I have never really messed with a carb before and cannot figure mine out. The guy i bought it from put a remaned carb on it but i dont know if everything is hooked up right. I am assuming its a feedback carb since it has the emissions stuff, here are a few things i noticed may not be right.
Where the gas line goes into the carb, to the right there is a capped off port.
There is something not plugged up on the right of the carb that may have something to do with the feedback i dont know, its 2 black wires coming off the bottom
I will try and upload some pics to help with
any advice on what i should do or maybe where i can get wiring/vacuum diagrams would be appreciated
Old 04-03-2012, 10:40 AM
1983F1503004x4 1983F1503004x4 is offline
1983F1503004x4 has a very good reputation on FTE.1983F1503004x4 has a very good reputation on FTE.1983F1503004x4 has a very good reputation on FTE.
Yeah, if you can, upload some pictures of the carburetor and the surrounding emissions components.
Also, take a photo of the distributor.
It sounds to me like the classic case of people not knowing what they're messing with.
He probably put a non-feedback carburetor on your computer-controlled carburetor setup. This is very bad, as you can imagine. But, we won't know until we get a look see. He could've just undone a lot of the emissions components, which is bad in itself because it makes the computer start tripping *****, and for the truck to run right you either do a DSII conversion or put everything back the way it was.
The port next to the metal fuel line is an external bowl vent. That runs to the charcoal canister down by the radiator support and battery. The line between the two T's off and runs to a Purge Control Valve at the back of the valve cover, which is hooked to the ported vacuum switch if I remember right, and the other line off the Purge CV goes to the little port on top of the PCV valve. Basically, this setup is called the Evaporative Emissions system, and recycles gas fumes so that they aren't vented to the open air. The engine inhales them and burns them off instead.
On the wiring/vacuum diagrams, your best bet is a factory shop manual (which can be hard to come by, but there are a few on eBay) or a Chiltons repair manual from the auto parts store and the vacuum diagram on the radiator support under the hood.
Old 04-03-2012, 11:30 AM
shaw4825's Avatar
I just noticed that i have no o2 sensor that i could see up by the manifold going down to the cat, looks like the exhaust has been replaced all the way back, whats the best way to post pics?
Old 04-07-2012, 12:48 PM
Xenthrax's Avatar
Xenthrax Xenthrax is offline
Xenthrax is starting off with a positive reputation.
Pictures for sure would be at the moment the BEST you could give us
You can take a picture of the carb setup, and upload it to photobucket, and then post a link here that directs us to your photobucket page (you might have to create a free photobucket account)
You could in theory upload it up to the thread itself without any links to another site, however if your a regular member like myself, we have a 800x600 pixel limit
Old 04-07-2012, 01:35 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Quote:
Are you sure? Where the heck did you get that from??????????????????
Old 05-01-2012, 11:18 PM
Rockman1157 Rockman1157 is offline
Rockman1157 is starting off with a positive reputation.
is it the mixture control solenoid? google a pic of what it should look like.
Old 05-02-2012, 11:18 AM
Quote:
I highly doubt he's going to respond. It's been a month and he hasn't replied or tried to tell us anything. And, unless he does, he won't be able to get any help from us.
Old 05-02-2012, 12:22 PM
ctubutis's Avatar
I doubt it, too. He's been an FTE member for over 2 years yet has only 15 posts to his name. This tells me he's periodically here only to leech information and get help from the user base and is not likely to contribute anything back to help others.
Actually, one can go see this for themselves... Find one of his posts, left-click his username, select "Find all posts by shaw4825" and you can see all the posts he's made/questions he's asked. No RFID chips needed.
Old 05-02-2012, 12:31 PM
Dave804's Avatar
Dave804 Dave804 is offline
Dave804 is a splendid one to beholdDave804 is a splendid one to beholdDave804 is a splendid one to beholdDave804 is a splendid one to beholdDave804 is a splendid one to beholdDave804 is a splendid one to beholdDave804 is a splendid one to beholdDave804 is a splendid one to behold
At least he uses punctuation?
Old 06-15-2012, 03:14 PM
chrisdunaway chrisdunaway is offline
chrisdunaway is starting off with a positive reputation.
need help
first off guys sorry to be taking over the post but how do you post a new thread and i changed the fuel filter on my 84 e150 is has a 300 inline 6 but cents i did theres a bunch of fuel leaking from under the carb sorry i new to working on carbs but my question is would changing the fuel filter mess up the gaskets or would it have lossen the bolts up like yall was saying up there and is there anyway to fix it with out geting a rebuild kit sorry kinda homeless and on the side of the road with no cash so any cheap fix will deff help thanks guys
Old 06-15-2012, 04:34 PM
ctubutis's Avatar
Quote:
Chris,
Welcome to FTE.
To start a new thread, go to the first page of the forum in which you wish to post and click the New Thread button on the top-left.
A good forum here on FTE for your engine is the 6-banger forum:
Ford Inline Six, 200, 250, 4.9L / 300 - Ford Truck Enthusiasts Forums
BTW I don't know of any reason why a new fuel filter would suddenly result in huge leaks, I would guess the body of the carb has been cracked but that's just a guess. Carburetors are made of real soft metal and don't take well to overtightening but there could be other causes, too (e.g. cross-threaded, etc.).
Old 06-15-2012, 04:39 PM
Dorsai's Avatar
Dorsai Dorsai is offline
Dorsai has a good reputation on FTE.Dorsai has a good reputation on FTE.
These carburetors are known to loosen up over time...if you've got a leak under the carburetor, you can try cranking down on the two nuts that hold the carburetor to the intake manifold.
However...I think the usual problem there is an air/vacuum leak, not liquid fuel coming out. Are you sure it's coming from there? Is it possible that when you changed the fuel filter, you cross-threaded it and now fuel is leaking from the threads and running down the front of the carb? I made that exact mistake myself years ago, on my old Comet that used the same (or similar) carburetor. I was able to use some kind of goop (don't remember exactly what...this was 25 years ago) to seal it up and get it back on the road, but ultimately I had to replace the carburetor.
Old 06-16-2012, 03:14 AM
Xenthrax's Avatar
Frankly I'm really surprised this thread made it all the way back to the front page
Good carb for 85 300 w/duraspark?? Greg Rogers Ford Inline Six, 200, 250, 4.9L / 300 7 07-26-2016 04:46 PM
300 6 non feedback conversion monkey jason 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 11-16-2013 10:51 AM
Feedback carb issues... custom1106 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 12-11-2010 08:33 PM
duraspark II swap mrob252 1978 - 1996 Big Bronco 1 04-03-2010 07:07 PM
Non-Feedback Carb w/ TFI-IV Ignition LARIAT 85 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 08-29-2006 02:55 PM
Tags
1977, 1983, 1986, 300, adjusting, adjustment, carb, carburator, carburetor, explorer, f150, ford, inline, removal, straight, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
