A/C Evaporator/Enclosure Box Question
I am replacing the evaporator on my 1985 F150. When I took the cover off the enclosure box (attached the the firewall), there was some sort of sticky glue or grease of some sort along the edge of the box and some on the evaporator itself. Is this supposed to be a gasket? The old evaporator itself was pretty nasty, so it is hard to tell. The evaporator enclosure box uses screws to attach the two halves together. Does the evaporator enclosure box supposed to be sealed with a gasket too?
Thank you, gentlemen.
How thick of a gasket do I need? And why does the enclosure box even need a gasket?
I just go to lowes or a hardware store and find some foam with the sticky on one side and use that.
Originally Posted by Gary Lewis
But I like the foam approach and use that instead.
And, the enclosure box will leak part of your air into the engine compartment w/o the gasket.
Why did you buy this catalog, if you aren't going to use it? With this catalog, you can answer your own questions. How many answers have you received so far?
Two One says remains of a foam gasket, t'other says black rope-a-dope putty = what's called dum-dum in the biz. Individual pieces look like licorice sticks, don't taste the same.
Available from automotive paint supply stores.
FordmanNJ
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
06-16-2013 10:58 PM
1987, 1999, 200, 85, 99, ac, clear, evaporator, evaportator, f150, ford, international, michigan, replace, replacement, truck, truk
