Suspension bits and pieces - Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
Old 04-03-2012, 07:59 AM
SSSimon SSSimon is offline
SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.
Hi all, at the recent GTG I was also looking at a number of trucks with sagged front suspension. If the front axle is less than 2" off the bump stops then it's sagged....
This is what I fitted to mine to lift the front of my truck:
2.5" 00-04 Ford F250/F350 Super Duty (Diesel) Leveling Lift Kit @Top Gun Customz
A few points:
1) the kit above actually lifted the front of the truck 3.5", probably because the front was sagged 1" from stock (2" from the top of the axle to the bump stop end).
2) After the leveling kit I need to lift the back half an inch to match the front. Because I rarely fully load the truck I purchased 3" rear blocks to replace the 2" blocks and fitted these AND took the bottom leafs off each side. This worked a treat and made the truck much less harsh in the rear, and it got the front and rear level. The bottom leaf is 1/2 an inch thick!
3) With softer suspension and more front suspension travel the truck actually steers better, handles better, and has a more comfortable ride.
4) As with many US sites, this site is also yet to learn that Australia is the 53rd state and won't ship here. To get around this I set up a Viaddress user ID. See :
https://www.viaddress.com
Basically you can set yourself up with a US address, then the Viaddress service consolidates your deliveries at your US address and ships them over to your Aussie address as one consignment. This can save you a bit if you are making multiple orders within the allowed free consolidation time (one month). Still expect to pay a lot to ship over suspension stuff - it ain't light!
Saggy suspension and lift questions Oregon04SD 1999 to 2016 Super Duty 3 11-03-2013 02:09 PM
Talk me out of adding air bags to all 4 corners 79wisc.roadmonster 1999 - 2003 7.3L Power Stroke Diesel 15 08-14-2013 07:04 PM
what would you level your 2004 SD with? SuperDutyScaler 1999 to 2016 Super Duty 6 01-18-2011 09:58 AM
Suspension Question which one Night Bird 1999 to 2016 Super Duty 6 04-05-2008 12:13 PM
Leafs & Level zman764 Offroad & 4x4 11 04-25-2007 10:26 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
ford, pieces
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
