Hot Air Choke connections
I did not know if I should jump on a similar thread or start a new one so her it is; 1978 F350 460 motorcraft 4350 (stock?) bought this a couple of week ago and think I found the no choke problem;
'A' is a press fit metal tube running to a rubber hose and then what looks like the hot air connection at the choke spring housing.
'B' is a soldered or maybe jeld weld glob probably covering something I need
'C' is a hole in air horn which had a broken nipple in it.
From the posts I have seen looks like the nipple at air horn should have gone to the plugged hole in manifiold? or tube connected to spring housing should go to air horn and hot air tube is missing?
bit off more than I can chew.....again.... any help is much appreciated.
frdf250
06-12-2016 12:06 PM
JStan
11-17-2003 03:26 PM
