I'm trying to replace the rear main seal. I posted a pic below. The orange seal on the bottom is the one that was in the motor. The seal on top is the one I'm having trouble getting back in. I'm wondering if I need a different seal?
I believe you need a seal driver the correct size and the seal gets driven into the block using a hammer. It is not a slip fit.
Thanks Jim!
I got it! I used a piece of PVC schedule 40 and a block of wood. I also got the flywheel, clutch, pressure plate, idler, throughout bearing, and new to me NP 435 in place!!
Amphenol, how did you get the old one out? Any special tools required? I just bought a Onan genset with what research shows to be a Ford CSG-649 300C.I.D. Looks like rear seal is leaking into the gen head. Thx.
