Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 04-02-2012, 08:41 PM
mudder460's Avatar
mudder460 mudder460 is offline
Garage is empty, add now
mudder460 is gaining momentum as a positive member of FTE.
Grill emblem removal
Ok, I removed the 2 nuts off the back of my grill emblem on my 08 Expy..... Now can you tell me why it will not come off? I had a screwdriver behind it but it seems like it is glued on. Any help?
__________________
Andy
2008 Expedition Eddie Bauer
Arkansas Chapter Member
  #2 (permalink)
Old 04-04-2012, 03:30 PM
fstaslp fstaslp is offline
fstaslp is starting off with a positive reputation.
Did you get the nuts off by reaching behind it? Were they metal?
  #3 (permalink)
Old 04-04-2012, 06:36 PM
RI-Matt's Avatar
RI-Matt RI-Matt is offline
RI-Matt is starting off with a positive reputation.
Maybe it was replaced before, the replacement ones have double-sided tape on them in addition to the speed nuts.
Matt
  #4 (permalink)
Old 04-04-2012, 08:39 PM
mudder460's Avatar
Yes the nuts were behind it and metal. It must be on there with sticky tape as well cause it will not come off. I will try the fishing line trik this weekend to see if it is sticky tape.
__________________
Andy
  #5 (permalink)
Old 04-14-2012, 11:45 AM
TIKT B8 TIKT B8 is offline
TIKT B8 is starting off with a positive reputation.
I bought my Expedition new and the grill emblem had the two nuts and double sided tape. I had to pry on it to get it off.
__________________
2007 Expedition Limited White Sand
  #6 (permalink)
Old 04-14-2012, 01:42 PM
07xpyebel's Avatar
07xpyebel 07xpyebel is offline
07xpyebel is starting off with a positive reputation.
Mine had delaminated, so I decided to paint it, I also had to pry it to get it off and in the process broke of the two plastic pins that the speed nuts connect to.
I painted and reinstalled using a small amount of auto motive adhesive.
Click the image to open in full size.
Tags
2007, 2008, badge, emblem, expedition, f150, ford, front, grill, grille, removal, remove, replacement, size, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
