Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-02-2012, 06:35 PM
vera martin vera martin is offline
Garage is empty, add now
vera martin is starting off with a positive reputation.
77 ranchero 351m
please help me having issues with the car need help, runs n sounds great but wont stay running when driving
  #2 (permalink)
Old 04-02-2012, 07:49 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
A little more info would/might be helpful.
__________________
Speed is a question of money. How fast "CAN" you go?
  #3 (permalink)
Old 04-04-2012, 04:56 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
The three step scenario of a failing Dura/Spark ignition module:
1) Module overheats, engine dies. Module cools down, engine restarts almost at once.
2) Module overheats, engine dies. Module cools down, engine restarts in an hour...or so.
3) Sooner or later, usually sooner, the module overheats, BURNS OUT. Now the engine will not restart.
Since these modules only fail when they overheat, taking it to a parts store to be tested...since it's cool, it will probably test OK unless the puppy has burned out.
Note: 1977/79 sold new in CA vehicles could have THREE different modules, TWO were CRAP from day one!
Look on the module above where the wires feed out for a colored plastic square. If it's red: notorious POS, if it's brown, not as notorious POS, if it's blue, best of the three.
The blue module will also be found on 50 state 1976's and 1977/79's not sold new in CA
1970's igntion modules were so prone to failure that Ford techs referred to Dura/Spark as Never/Spark!
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #4 (permalink)
Old 04-04-2012, 11:47 PM
RFAgrasshopper's Avatar
RFAgrasshopper RFAgrasshopper is offline
1927 Ford T
RFAgrasshopper is starting off with a positive reputation.
It could be many things! One could be the module as stated above. An other one could be a bad(carboned up) EGR valve that will allow it to start and then die when you try to drive. Depending what carb it has,it could be a blown power valve.
  #5 (permalink)
Old 04-05-2012, 12:18 AM
Ford Parts Guru
2013 Ford Escape
The original factory installed EGR/Carb spacer plates were made from aluminum. Not only does these EGR and their spacer plates carbon up, but heat caused the plates to MELT internally.
The FoMoCo service part replacement plates are cast iron, but are now obsolete.
__________________
  #6 (permalink)
Old 04-14-2012, 01:51 AM
chamblizi's Avatar
chamblizi chamblizi is offline
1975 Ford Ranchero
chamblizi is starting off with a positive reputation.
Time for a Motor Flush and a tune up...
When is the last time you did a full tune up and inspected your spark plugs as well for flushed your engine? a bad air filter can choke out your engine.... depending on how the filter box is made on my ol 89 f-250 when i first got it it had a start then fail problem which come to find out was nothing but needed a oil change and a airfilter change there was motor oil all in the filter box when i got it which choked it out.
  #7 (permalink)
Old 04-15-2012, 12:34 PM
parts4me's Avatar
parts4me parts4me is offline
1978 Ford Ranchero
parts4me is starting off with a positive reputation.
I would start with a list of possible problems that you could address and start with the simple repairs and hopefully one of them will be the problem, I would bet it is an EGR issue.
Tags
1977, 351, 351m, 76, 77, ac, capasity, harness, home, made, pos, ranchero, specs, wiring, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
