HELP! fuel rail temp way to high after being in shop
hit a brick mailbox and got my truck back from the shop today with a new bumper replacement on it and with regular driving my eft1 was up to 150 degrees!
it was 89 degrees outside and im on the 250 egr tune
do you think they could have installed something wrong?intercooler?
Your fuel cooler is just behind the degas bottle (itty-bitty rad.cap). It is not plumbed in with the engine coolant (same stuff though). You should see coolant in the sight glass.
Yes on its own circuit (fuel cooler) and takes the same ford gold coolant. I mentioned it since he had front end damage and the symtom of the fuel rail temp to high. Filler up and see if that helps. May take a bit to get the air worked out.
