Gear lube for Doug Nash dne2 overdrive - Ford Truck Enthusiasts Forums
Old 04-02-2012, 06:11 PM
SuperDutyGuy06 SuperDutyGuy06 is offline
SuperDutyGuy06 is starting off with a positive reputation.
I searched all the forums here and online and cannot find what type of oil to use in a dne2 2 speed overdrive from the mid 80s I put in my 40 Ford pickup street rod.I am aware that DN sold out to US gear,which I spoke to a few years ago,USG was again sold and no one there knows anything anymore as of today when I called.The DN 2 speeds in the Corvettes take Dextron III,and the Gear Vendor ODs take a special GM or Mopar manual type gear oil.All the things I found out about the dne2 in the last few years,say the lube type is VERY important and to only run 1qt. as it will over heat if over filled.Anyone know for sure what lube it takes? There was a few posts on here a few years back that the guys said they had a manual....anyone still out there? Thanks Jack
Looking for DNE2 e4od knowledge jayro88 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 04-16-2015 08:27 PM
Help Bypassing DNE2 - 1986 Ford F250 6.9D lonestarcruiser 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 05-13-2009 11:50 AM
AUX overdrive/underdrive question Northwest ohio Clutch, Transmission, Differential, Axle & Transfer Case 1 10-20-2008 02:50 PM
Need DNE2 parts or info. grnburg N. California Chapter 1 11-24-2005 11:13 PM
DNE2 Overdrive unit Endo51 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 06-30-2003 01:53 AM
Tags
dne, dne2, documentation, doug, gear, manual, nash, overdrive, owners, parts, shooting, speed, transmission, trouble, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
