Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 04-02-2012, 05:16 PM
chestonking chestonking is offline
Garage is empty, add now
chestonking is starting off with a positive reputation.
1993 ford lightning
I have a 93 ford lightning that i would like to put a 393 into it. I was wondering if my heads and intake would be enough for it or would i have to get different ones. Also if i can use my GTP 40 heads what kind of pistons would you recommend for the best compretion ratios as far as flat tops, domed, etc. any advice is greatly appriciated.
  #2 (permalink)
Old 04-02-2012, 06:03 PM
Blurry94's Avatar
Blurry94 Blurry94 is offline
1994 Ford Lightning
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
What kind of power are you looking to make, how much are you looking to spend and what type of driving do you do with this truck?
__________________
Matt C.
Intercooled Vortech, Victor Jr. heads, roller cam, 62lb injectors, 2800 stall converter, Eaton Locker, Pickrel Headers and Exhaust, FMS Mass Air using SCT tuning software. Road trip and dragstrip ready!
  #3 (permalink)
Old 04-02-2012, 06:18 PM
I was looking to push around 400 horsepower. Money isnt to big of a deal because this will be a project that will take me awhile to do. Right now the truck is my daily driver until i get another truck.
  #4 (permalink)
Old 04-02-2012, 08:11 PM
Blurry94's Avatar
1994 Ford Lightning
What kind of tuning options are available to you; speed density is going to be a limiting factor and only a small handful of tuners can tune those systems.
__________________
Matt C.
  #5 (permalink)
Old 04-02-2012, 11:35 PM
are you talking like a dyno shop or tuners that you do yourself? I dont really know much about all that.
  #6 (permalink)
Old 04-03-2012, 06:36 PM
Blurry94's Avatar
1994 Ford Lightning
The reason I ask is because you're going to be limited as to what you can do with speed density. A shop tuner that knows speed density well, can tune one with more cubes but your cam choices are going to be limited. Your other options would be a mass air swap or aftermarket engine management like BigStuff or FAST and you can choose just about any cam you like. I tend to lean towards a custom grind cam and if your block has an F4TE casting number then you can do a roller cam swap. GT-40 heads on a stroked 5.8 will be a restriction so a set of Edlebrock, AFR or Trick Flow would be a better option.
Other things to consider will be the drivetrane. The factory locker wont last long with the added torque. They can be rebuilt with better parts or you can change it out with another type of locker, like an Eaton. Wheel hop is another issue with these trucks so installing a set of traction bars will save you from snapping an axle when you get a little happy with the throttle. Another good upgrade would be a valve body upgrade to firm up the shifts. Hope this helps.
__________________
Matt C.
  #7 (permalink)
Old 04-03-2012, 07:14 PM
Thanks yeah that helps. I already have traction bars and have upgraded my locker in the rearend. There is also a **** kit put in the truck. Thanks for the advice.
  #8 (permalink)
Old 04-03-2012, 07:20 PM
That was supposed to be shift kit. Apparently my phone has a mind of its own. Hahaha
Tags
1993, 2012, 93, bars, exhaust, ford, forum, kind, lightning, saleen, system, traction, truck, trucks, upgrades
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
