ecm swap questions
I think most tuners use the PMT1 as a base for their tunes.
"Some vehicles may exhibit an engine buck, surge, or jerk (also known as hitching/hesitation) while the speed control is active through all engine temperatures. This may be caused by the calibration and strategy of the Powertrain Control Module (PCM)."
TSB 00-25-04 - 1994-1997 Power Stroke FAQ
I only ask because nearly all of the "tuners" out there use the software and definitions that my boss has put together. I get to deal with the codes in question all the time.
The "changeable parameters" you're talking about are nearly identical between XLE4 and PMT1. It seems to me that anybody that says an XLE4 is not as "tune-able" as a PMT1 is too lazy to spend the time on making tuning for an E99 truck. Sure, there are a few inherent weaknesses in the base strategy (mostly concerning torque converter clutch apply/release criteria), but an XLE4 makes power and shifts using the same list of "changeable parameters" that a PMT1 does. In addition, once a truck with either calibration is above 45 MPH and the transmission is in 4th gear and the torque converter clutch is applied, there is NO DISCERNIBLE DIFFERENCE between either one.....or ANY Super Duty automatic PCM code for that matter. Forced downshifts are different, but I'm talking steady-state cruise conditions.
Do I prefer using one over the other? Of course. The PMT1 wins hands-down for me because of how I use the truck. If I were to have a daily-driven truck that simply cruised around town and drove up and down the highway unloaded (like someone would use a truck for a commuter vehicle, right?), then the XLE4 would work excellent. However, since I tow and USE my trucks fairly consistently, the XLE4 irritates the hell out of me.
Not sure if this is what the OP is referring too but here is something to look at.
Thank you for the insight. Im no expert, I'm just going with what I have been told by different tuners. (and I may have misunderstood them )
When I asked my fist tuner (xle4 pcm at that time) if there were any updates he said not much has changed on the e99 tunes. The updates were more for the later 99.5+ trucks.
My second tuner asked if I wanted to update my xle4 to a later pcm because he could change more parameters( I'm prob not using the correct term) compared to the e99 pcm's...
It made me think the e99 pcms were worthless when it comes to tuning.
