Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 04-02-2012, 11:34 AM
rollinblackcloud rollinblackcloud is offline
Garage is empty, add now
rollinblackcloud is starting off with a positive reputation.
ZF5 grinding into reverse clutch all the way in!
Hey guys 94 f250 7.3 ps zf5. Latly my clutch hasnt been doing well, whenever i go into reverse, it grinds like hell and wont stop, clutch to the floor, trick not rolling. Is my synchro out? Is there an adjustment? A clutch brake? From 1st to second it does it sometimes for a split second. Also from a stop sometimes it doesnt like to go into first, gotta hold it there for a min before it goes in. Only thing i can think of is a clutch brake that slows the gears?
  #2 (permalink)
Old 04-02-2012, 12:41 PM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is online now
1996 Ford F-350
DIYMechanic has a great reputation on FTE.DIYMechanic has a great reputation on FTE.DIYMechanic has a great reputation on FTE.DIYMechanic has a great reputation on FTE.DIYMechanic has a great reputation on FTE.DIYMechanic has a great reputation on FTE.
There is a plastic bushing on the clutch push rod that can go bad if I remember correctly and cause this exact symptom. Another thing to check is to sick you head under the dash and move the pedals by hand and see if there might be a chance that the pedalbox (the bracket that holds the pedals) is cracked or broken. Someone with more experience in these will undoubtedly be along shortly, but this will give you something to look into in the mean time. It sounds to me like the clutch isn't disengaging completely.
__________________
--Nate "Just a redneck geek"
1996 F-350 7.3L PSD, 4x4, CCLB SRW, 3.55's, E4OD, EBPV Delete, 3" DP, Stock Tailpipe and Muffler, Riffraff 6637 Intake, 400,000 miles and counting.
If it isn't under warranty, I'll fix it myself.
  #3 (permalink)
Old 04-02-2012, 07:03 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld has a very good reputation on FTE.ReBilld has a very good reputation on FTE.ReBilld has a very good reputation on FTE.
I agree with Nate, the end of the push rod on the master cylinder would be the first place I'd check. That cause exactly what you are describing.
Tags
73l, 94, bad, bushing, clutch, disengage, doesnt, ford, grind, grinding, ranger, reverse, rod, signs, zf5
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
