Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.0L Power Stroke Diesel 2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 van SPONSORED BY:
  #1 (permalink)
Old 04-02-2012, 09:19 AM
florida_1959 florida_1959 is offline
Garage is empty, add now
florida_1959 is starting off with a positive reputation.
Potential Problems?
I know it is not the exact forum to post this, but there is always so much great info fromt he guys on the 6.0 pages, so I figured I would get some good answers here. I have a 2006 F250 CC 4wd that I need to replace the tires on. There are so many people upgrading wheels and tires that Craigs list has a ton of 20" factory rims and tires for less than I could replace just my 18" tires for. My question is what kind of problems would I have going from 18" to 20" rims? Is it something that could be recalibrated? I would assume the speedo would be wrong, but not sure what else the swap would throw out of balance.
thanks
  #2 (permalink)
Old 04-02-2012, 01:38 PM
Rusty Axlerod's Avatar
Rusty Axlerod Rusty Axlerod is offline
Rusty Axlerod is a splendid one to beholdRusty Axlerod is a splendid one to beholdRusty Axlerod is a splendid one to beholdRusty Axlerod is a splendid one to beholdRusty Axlerod is a splendid one to beholdRusty Axlerod is a splendid one to beholdRusty Axlerod is a splendid one to beholdRusty Axlerod is a splendid one to behold
Not a problem at all if you get a shorter tire for the taller rims the overall height stays the same. For example a LT275-65-20 is (pretty much) the same as a LT275-70-18. No effect on speedometer. All of 'em should be balanced before putting them on your truck so no worries there. If you're looking to go BIG, you'll need a little lift for body clearance, and the speedo' calibration can be changed with a computer.
  #3 (permalink)
Old 04-02-2012, 06:18 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a brilliant futurecheezit has a brilliant futurecheezit has a brilliant futurecheezit has a brilliant futurecheezit has a brilliant futurecheezit has a brilliant futurecheezit has a brilliant futurecheezit has a brilliant futurecheezit has a brilliant futurecheezit has a brilliant futurecheezit has a brilliant future
if its off you can go tot hte dealer and have them retest to oem 20" not an issue
__________________
Former Ford Senior master tech, gas and diesel.1992-2012
ASE Master Tech, L1 certified.
2006 f250 cc swb fx4 6.0
mods arp,egr delete, tuned, 91 gallon RDS fuel tank.
  #4 (permalink)
Old 04-03-2012, 03:48 PM
Here's a nifty, easy to use calculator for tire size and speedo' error. Will give you some idea if the tires your thinking of using makes a difference and how much.
Speedometer Calibration Calculator And Information
__________________
2006, King Ranch, F250, Lariat, Super Duty, Powerstroke, FX4, CC, SRW, 20in Ultra Motorsports Goliath wheels. Husky 16K roller hitch, ScanGaugeII. Sinister coolant filter. Blue spring. BPD EGR cooler. Riffraff CAC boots w/metal cold side tube, STC update. Fumoto valves. CAT ELC.
  #5 (permalink)
Old 04-03-2012, 05:52 PM
zhilton's Avatar
zhilton zhilton is online now
2004 Ford F-250
My Garage
zhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to all
If you want to go bigger than 37" (think that's the max on IDS) you'll need to find someone with an AutoEnguity to change the speedometer.
And for the record, from '99 through current production...they use the same bolt pattern. Just in case you were wondering.
__________________
FTE Arkansas chapter member
1972 Ranchero GT (351C CobraJet intake)
2001 Explorer XLT 2WD
2004 F250 6.0L 2WD CC "Pavement Princess"
2007 Monaco Starwood SL 31BHD
2012 Focus SEL (Wife's ride)
  #6 (permalink)
Old 04-04-2012, 09:16 AM
2008fordguy 2008fordguy is offline
2008fordguy is starting off with a positive reputation.
Yes, the same bolt pattern- don't forget, the newer trucks use different BS, and offset...
__________________
2004 F-250 Lariat 6.0L CC LB FX4
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
