Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-02-2012, 08:45 AM
lance65's Avatar
lance65 lance65 is offline
Garage is empty, add now
lance65 is starting off with a positive reputation.
frame questions....
I have a '59 F250 cab and front clip...was a complete truck,but someone wanted to buy just the cab and front clip and a section of the frame,so I cut and scrapped the rest of the chassis and suspension....well the sale did not go through and I am left with this cab in my driveway.
SO my question is, can I use,and will it work, a frame from the '61-'63? I'm talking about the ones the used the '57-'60 beds? I have found a few short bed frames and beds for that era,but dont know if they will work. Thanks
  #2 (permalink)
Old 04-06-2012, 11:20 AM
lance65's Avatar
86 views and nobody has info?
  #3 (permalink)
Old 04-06-2012, 11:57 AM
2losteve 2losteve is offline
2losteve is starting off with a positive reputation.
2losteve 2losteve 2losteve
Maybe posting in their forum (61 - ?) might get some response.
__________________
'56 F-100 - on the road 12 yrs
'57 F-100 - waiting
'54 Chev sedan del - in construction
'71 C-10 daily driver
'65 Riviera
'08 Roadglide
  #4 (permalink)
Old 04-06-2012, 05:23 PM
elgemcdlf's Avatar
elgemcdlf elgemcdlf is offline
1970 Ford F-100
elgemcdlf is gaining momentum as a positive member of FTE.
I would guess almost nobody has done something like you describe. Usually when one does a frame swap they move into a far newer chassis Where are you located? I can get you a correct frame out of NV.
  #5 (permalink)
Old 04-06-2012, 07:43 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
When I first read this all I wanted to say was "why?" ! Then I figured that wasn't the help you were looking for. If you have the '61 frame available now, just take some guick measurments. It should not be hard to measure the cab already off the frame. The trucks shared the same front end up till '64 so they might be compatible but am not sure without measuring for myself. My hunch would say that the '61 body is wider than a '59 thus requiring a different frame so it might not be that easy.
So there's a reply with bunch of guesss and not really anything to go on but you can feel better that you got a response. I believe folks just don't know your answer and most here usually don't just respond to up their post count. So be patient and try posting in the other forum as suggested by 2loststeve.
  #6 (permalink)
Old 04-07-2012, 05:25 PM
hotfalcoon's Avatar
hotfalcoon hotfalcoon is offline
1957 Ford F-100
My Garage
hotfalcoon is starting off with a positive reputation.
I agree, take some measurements. I believe the frame width is the same at 34" and wheel base should be the same as well. The '57-'60 trucks wheel base is 110" for SWB and 118" for LWB. You will probably have to modify the frame mounts for the cab.
  #7 (permalink)
Old 04-07-2012, 10:51 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
If you have a torch, welder and a little "know how" anything's possible.
__________________
Speed is a question of money. How fast "CAN" you go?
  #8 (permalink)
Old 04-08-2012, 02:39 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1961/63 F100 long wheelbase is not the same as 1957/60 and there is more than one length when you consider Uni's, Stylesides that used the 1957/60 bed.
1964/66 F100 is different again.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #9 (permalink)
Old 04-09-2012, 07:17 PM
lance65's Avatar
the wheel base doesnt matter to me much. I prefer a longbed 3/4t 'cause I want to do a custom flatbed. My concern is the frame from a '61-'63 is not flat under the cab. I have even thought of using brand "X" 1t dually(crewcab) chassis mainly 'cause it is flat or even a Ford '73-'79 Supercab chassis. I can make body mounts and put them where I need.
Anyone know the WMS(wheel mount surface) to WMS of a '57-'60? Thanks
  #10 (permalink)
Old 05-10-2012, 10:48 PM
montego69 montego69 is offline
montego69 is starting off with a positive reputation.
Lance65,
I looked into using my rustfree '60 F100 body on a '62 4X4 chassis awhile back. I found that there is very little in common between the two generations when looking at mounting points. The widths, lengths, and elevations are all different. It wouldn't be impossible to make it work. Some welding is all it would take.
I ended up swapping the 4X4 stuff to my '60 after finding the unique transfer case brackets. In the end it will look like a stock 4X4 only in shortbox version.
When you mention WMS, do you mean the overall width of from axle flange to axle flange or track width?
Nick in WI
  #11 (permalink)
Old 05-11-2012, 05:24 PM
dmannservice's Avatar
dmannservice dmannservice is offline
1960 Ford F-100
dmannservice is starting off with a positive reputation.
! could sure use that cab and clip on my '60 4x4 !
Tags
110, aftermarket, frames, truck, wheelbase
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
