2011 Expy transmission hard shifting…. - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 04-02-2012, 05:47 AM
alsager512 alsager512 is offline
alsager512 is starting off with a positive reputation.
Dear, All
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
I have google long time to find answer and solution for my problem. But that was useless.
<o></o>
My 2011 Expy (20,000 KM) is have problem with transmission when it up shifting 1-2. This problem happens sometime, and when I accelerate truck from stop for one second and before 10 km/hr, I remove my foot and leave the tuck without accelerating and without break also. So, then transmission do harsh shifting from 1-2 with bump. Same thing happen when it shifting from 2-3.
<o></o>
With smooth accelerating, all things work good, but still I feel slight bump with deceleration.
<o></o>
I have visits my dealer two times, but no benefits.
So, can you help to understand what is going with transmission?
<o></o>
Thanks
<o></o>
Old 04-03-2012, 05:09 PM
1960 1960 is offline
1960 is starting off with a positive reputation.
I had the same trouble with my 2011 Expy el I took it back to the dealer 4 times They kept telling me nothing was wrong so the would reflash it and it would work for about 3 days then shift bad again. It was worse when I towed my trailer. Then it started to act up in reverse. then the dealer found a seal bad inside of the transmission and replaced it. It helped but did not completely fix it. So I filed a Lemon law suit thru the BBB. That got their attention so they put a new value body in it. And that took care of most of the problem. Ford also said they know they have problem, ford thinks it is in the learning side of the transmission controler. and are working on a fix. Ford did give me a 5 yr 75000 mile service contract and a 3yr maintenance contract and will get back to me on a fix.
So far it is working pretty well also I nolonger tow with it.
Old 04-04-2012, 05:35 PM
thanks for replay.....
I will try to push my dealer to replace valve body in next visit.
2000 Ford Expedition xlt battery saver relay clicking no start websurfer 1997-2006 Expedition & Navigator 13 11-14-2016 03:22 PM
1966 f100 door tag decode request plum bob 1961 - 1966 F-100 & Larger F-Series Trucks 1 02-10-2015 08:17 PM
Glow plug #7 Remove and Replace question egregg57 6.0L Power Stroke Diesel 6 09-15-2014 05:27 PM
2011 F350 Towing Noise njload 6.7L Power Stroke Diesel 4 08-05-2014 02:09 PM
3 Post to 4 Post Alternator Question clarkbre 1967 - 1972 F-100 & Larger F-Series Trucks 2 04-28-2014 11:40 PM
Tags
2008, 2010, 2011, connect, expedition, ford, forum, hard, harsh, rough, shift, shifting, shifts, signs, transit, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
