Engine Problems - Ford Truck Enthusiasts Forums
Engine Problems
Old 04-02-2012, 02:23 AM
dogger123 dogger123 is offline
dogger123 is starting off with a positive reputation.
Engine Problems
Hello.
I'm new here and I live in Germany.
I have a Ford f150 4.2 RWD 5-speed manual shifter.
I love this truck.
But I have a little problem.
My car stutters a bit when I accelerate slowly.
I have made ​​clean new spark plugs. Autolite Platinum 105 single.
And I have new spark plug wire in it. New air filter.
The car speeds but still not right.
Feels like not enough fuel or not fast enough.
or when the spark plugs were dirty with soot. just that feel.
But the candle picture looks good.
Could it be the sensor? O2 sensor, or the something like this????
Oh i have more questions . What kind of 5 Speed manual transmission,
Engine and Differential Fluid ( Oil) do you use????
I think engineoil is 5w30
....Transmission is ATF Oil ???
and Differential...i dont know
Thanks for the replies and sorry for my bad English!
I've found your nice forum. Here in Germany, the truck is unfortunately not represented as often. Too bad. So in Germany there are not that many that can help me.
Thank you
Greetz
Sven
Old 04-15-2012, 11:06 AM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
What is a "candle picture"?
Old 04-15-2012, 11:09 AM
Its the name in Germany :-)
The Plug looks good!
Its not to Black and not to white.
its a good Candle Picture ........
Old 04-16-2012, 01:14 AM
Lead Head Lead Head is offline
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
Try cleaning the Mass-Air-Flow sensor (make sure you use sensor safe cleaner), and changing the fuel filter.
Also, you will get much more help in the proper F-150 section in the main forum index.
1986 F-150 i6 Carb or electrical problems? Bullnoser Ford Inline Six, 200, 250, 4.9L / 300 20 03-13-2017 12:41 PM
Norwegian build Sondre Næss Excursion - King of SUVs 4 02-25-2017 05:57 AM
engine swap david024 1987 - 1996 F150 & Larger F-Series Trucks 3 02-10-2017 05:33 PM
Anyone ever use Majic tractor paint? 650 1973 - 1979 F-100 & Larger F-Series Trucks 7 10-22-2016 07:09 AM
What spark plugs are you guys using? Justin73supercamper 1973 - 1979 F-100 & Larger F-Series Trucks 9 10-21-2016 08:54 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1966, coyote, engine, engines, ford, problems, shooting, trouble, troubleshooting, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
