Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-01-2012, 08:39 PM
timmyboy76's Avatar
timmyboy76 timmyboy76 is offline
Garage is empty, add now
timmyboy76 has a very good reputation on FTE.timmyboy76 has a very good reputation on FTE.timmyboy76 has a very good reputation on FTE.timmyboy76 has a very good reputation on FTE.
timmyboy76 seadooya
f/p reading with no fuel?
Scratch'n my head on this one, guys. Long story short, installed wvo system, TOTALLY isolated system. Only thing sharing is the fuel rail.
With wvo pump run'n, fuel bowl drained, and having CV's on diesel fuel line side, i'm still registering psi on my diesel f/p gauge , and no (run'n diesel thru wvo system to check for leaks), no diesel is get'n past cv's to fill bowl up. I let it idle for abit, along with revving motor, and no fuel present in bowl, but f/p climbed to 60psi? Whats goin on, lol?
O-ya, have a switch to turn diesel side pump off, which it was off.
Any input is greatly appreciated.
__________________
TIM...PAA#113....plenums inserts, hpx, frx, 50 cent, gauges, trans-coolant-oil DIY by-pass systems, H/H mod, DIY WVO system 156k and counting
  #2 (permalink)
Old 04-02-2012, 10:41 AM
timmyboy76's Avatar
timmyboy76 seadooya
i'm wondering if my signal wires between the 2-sensors are communicating. The wvo sender is located on the "manifold" in the valley, where the other sender(d2) located on the fuel bowl. Both signal wires are sharing the same loom. Gonna disconnect either the ground or + wire from D2, and go from there....only thing i'm coming up with?
__________________
  #3 (permalink)
Old 04-02-2012, 11:27 AM
timmyboy76's Avatar
timmyboy76 seadooya
Found it. The 2 senders were communicating...i disconnected the wvo sender, but ran truck on wvo pump, and no reading was present on D2 gauge...
__________________
  #4 (permalink)
Old 04-03-2012, 06:41 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
Good to hear you have it figured out. Don't mess with the stuff except to make bio.
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
Tags
ford, guage, truck, wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
