Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > EcoBoost (3.5L, 2.0L)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
EcoBoost (3.5L, 2.0L) 3.5L Twin Turbo EcoBoost V6 and 2.0L I4 EcoBoost Engines
  #1 (permalink)
Old 04-01-2012, 08:31 PM
Boss9F100's Avatar
Boss9F100 Boss9F100 is offline
Garage is empty, add now
Boss9F100 has a good reputation on FTE.Boss9F100 has a good reputation on FTE.Boss9F100 has a good reputation on FTE.
EcoBoost Trans Temp _ Max Boost_ Tuner
Towing a 5000lb trailer @ 60mph with a ambient temp of 70deg I was seeing 199deg trans temp. It was barely working, level ground and was quite surprised to see that temp. What is everyone else seeing for trans temps while towing, especially if heavier loaded.
Also what is the Boost in lbs the EB makes? I do not see it in any literature or elsewhere online.
What is best tuner to buy for the ecoboost? I see a few with SCT.
How about actual horsepower gains with tuner, exhaust and air improvements?
__________________
1966 F250 Deluxe Camper Special "RANGER" Special Paint
1965 F250 Deluxe Camper Special Unrestored Original
1966 F100 powered by a 482" Dual Quad Side Oiler
1966 F100 Plain Jane AZ Grandpa Truck 352 3spd
1966 F250 Plain Jane Red/Red Long Bed 3.5L EcoBoost
02' PowerSmoke
  #2 (permalink)
Old 04-23-2012, 06:24 PM
EcoboostKev's Avatar
EcoboostKev EcoboostKev is offline
EcoboostKev is gaining momentum as a positive member of FTE.
Pulling our camper(7500lbs) depending on how big the hills are the temp runs between 190-200. I think the boost level is around 13-14lbs. I wouldn't chance putting a tuner on it until the warranty is done. Ford wont show you the time of day if they knew you had a tuner on it.
  #3 (permalink)
Old 04-23-2012, 06:45 PM
Fishstyx Fishstyx is offline
Fishstyx is starting off with a positive reputation.
Those trans temps don't look out of line. Mine reads 190 just cruising down the highway unloaded.
I read somewhere that max boost was in the 14lb range.
The EB is already engineered to squeeze a lot of power out of a small engine. One is taking a serious gamble by messing with it and there isn't much to be gained.
  #4 (permalink)
Old 04-24-2012, 12:56 PM
thomastl thomastl is offline
thomastl is starting off with a positive reputation.
16 lb is the max I have seen on my boost gauge.
As has been said, tuner will void the warrenty if you have an engine failure. Acording to my service manager, the first thing they do on a blown engine is send the computer to Ford. Ford checks and can see if it has ever been tuned (even w/ a handheld unit). If it has, no warrenty. Of course this would only apply on an actual blown engine or turbo. Anything else external and they would probably never know.
Tags
boost, buy, eco, ecoboost, econoost, f150, maximum, sct, temp, temperature, towing, trans, transmission, tuner, tuners
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
