72 crew cab long bed cummins
Old 11-18-2015, 10:17 PM
crazed87bronco's Avatar
crazed87bronco
crazed87bronco is offline
Those traction bar brackets turned out great. They should keep from any axle wrap that would happen with those huge blocks on the rear. Are you planning on going with full leafs with a smaller block at some point? The truck looks to be just about done with some finishing touches yet.
  #707
Old 11-19-2015, 10:25 AM
highntight's Avatar
highntight
highntight is offline
Thanks man... Ya kicking some ideas around, may do a shackle flip in the future. But for now I think they will be fine. Im hoping the front settles an inch or so I had enough pieces cut to build another set of blocks if I had to as well. Its getting closer for sure, lots of small stupid stuff that sucks up a lot of time. Slowly but surely its coming together. I would like to drive this thing someday lol.
  #708
Old 11-20-2015, 10:52 AM
highntight's Avatar
highntight
  #709
Old 11-20-2015, 11:16 AM
Gembone's Avatar
Gembone
Gembone is offline
Why did you decide to go with the massive blocks instead of bigger springs?
  #710
Old 11-20-2015, 01:48 PM
crazed87bronco
Bars are looking good on it. They getting painted black as well? Are those Bilstein shocks your running? What series are they? I been looking into shocks lately since they will be coming up on the to do list soon. I want to run Fox racing ones but they are salty priced. I've seen a lot of good things on Bilstein's and good prices so they are another option for me.
  #711
Old 11-20-2015, 03:48 PM
highntight's Avatar
highntight
Gembone... Glad you asked,
Mostly because I had no idea what I was doing when I started this build lol. I Knew I didnt want an all spring lift in the rear, maybe have to run a 4 inch block or something like that. Once I got closer to the end It was easier to stuff some big blocks in. I Never meant for the front to end up so tall. That about sums it up. I have been kicking the idea around of a shackle flip or maybe having AAA spring bend something up in the future but for now I going to get it moving and that will give me a better idea on what needs to be reworked in the future.
Crazed...
I ran blistein's on my dodge and always liked them, but like you said there are others that are just as good. The 5100 series are what you want to run. I downloaded there chart and just picked off of there for the sizes that worked for me. They come as 5110's or something like that. There bull.... way of not giving you a better warranty because they were not order for a specific vehicle. So that part is kind of a bummer.
  #712
Old 12-04-2015, 09:10 PM
scottfreeman's Avatar
scottfreeman
scottfreeman is offline
Wow
Simply wow.
Great job. That is over the top.
  #713
Old 12-06-2015, 04:26 AM
GaryKip's Avatar
GaryKip
GaryKip is offline
A great job to be sure! I like those BigA*S blocks. Are you going to rotate the axle/diff to help relive the u-joint strain? Or are you using a two piece drive shaft?
  #714
Old 12-07-2015, 02:53 PM
highntight's Avatar
highntight
Originally Posted by scottfreeman
Simply wow.
Thank you sir, mighty kind of you....
Ha ha Ya there big for sure. Speaking of drive lines did a bunch of measuring this weekend for them. Im 88" long in the rear, So two piece for me. Not a big deal since I assumed thats what I would need to go with. Speaking with the shop there telling me 82 is as long as they will do a one piece. On this axle I had to redo perches anyways so I set angle then. My output is sitting at 85 deg down and the flange on the axle is 85 deg up. So its sitting perfect for a one piece so thats to bad. Thanks buddy......
  #715
Old 12-07-2015, 03:02 PM
highntight's Avatar
highntight
Pushed the truck outside for a min to clean up a little and took a few pictures...
pretty dusty and dirty
Crazed..... took a picture where I had to clearance the grill
Also got the hood latch accomplished. Works like new. nice easy push latches it perfect. Got it all powder coated and reinstalled Sunday. Still need to put a pull cable on it. A wire is preforming as the pull cable night now.
  #716
Old 12-07-2015, 05:04 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Man, that's a Bad Azz lookin' truck. With a capitol B. Even though I personally am a fan of chrome. I like it. I can't wait to see a pic of it 1/2 way up a snow drift.
I'll have to go back through this thread. I don't remember seeing you doing that hood latch swap. Way Cool Zack. Heck, I think I'M gonna pop a cork once you call it complete!
  #717
Old 12-07-2015, 08:52 PM
crazed87bronco
Trucks killer looking outside. Thanks for getting a pic of the grille. What did you all have to do for the hood latch? That's one of the things I need to get done yet. It looked like I need to get creative on the latch when I had the front still on.
  #718
Old 12-07-2015, 10:17 PM
nutter3's Avatar
nutter3
nutter3 is offline
I had my 2 piece driveshaft / carrier bearing in my 2006 Megacab replaced with a one piece shaft from Doghouse Diesel. It was a huge 5"OD aluminum shaft, very nice quality. It made the truck so much smoother. I can't remember the exact length, and I can no longer find Doghouse Diesel online. But that mega cab is one long SOB, perhaps you can find someone else who will make you a one piece shaft.
  #719
Old 12-07-2015, 10:19 PM
nutter3's Avatar
nutter3
nutter3 is offline
I posted too quickly, right after I posted I found his phone number
Richard Silvano
Owner, Doghouse Diesel Performance
Doghousediesel.com
706-888-2877
  #720
Old 12-08-2015, 12:44 AM
GaryKip's Avatar
GaryKip
GaryKip is offline
I don't how close to any bodies of water you are, but a Marine prop repair shop could make you a long enough shaft.
Quick Reply: 72 crew cab long bed cummins
