72 crew cab long bed cummins
#511
Jeff,
Well two days ago I would have agreed with you lol.... But Now Having messed with that one stupid window for 3 days I dont think its the weight that whooping me. I can adjust it ether go down smooth and up rough or up smooth and down rough. Cant seem to find that perfect medium. I cant win at the moment so I walked away again and will go back to it in a min... But I will get it for sure. As for the piece I tried to stay as small as possible but had a little somethin to it... I been cutting it out of some grating I had laying around. Some old beat up 1/8th inch stuff... Stupid window anyways lol
#512
#513
HAHAHAHA you just made my day lol... Your definitely on the right track... These are aftermarket window regulators that work with all flat glass 6" to 24" except for 72 crew cab long bed cummins pasenger side rear doors lol They forgot to put that last part on the label though. I have put all new rubbers, guides, and every-stuff in the doors. But with as funny as what you said is, It is something to angle and where it is placed. Its just a matter of finding that sweet spot at this point I think....
#514
Aftermarket aaay? If it's the kind that has a window lift bracket that has slides that grab the sides of the vertical track lube it there with something like white lithium grease. Also try knocking something slightly out of alignment. Like driveshafts aren't perfectly in line. Kicking the bottom of that track a skosh for or aft?
#515
#516
#517
I did finally get my window switches done. There was no way I was paying 100 bucks a switch so I ordered 25 amp micro switches 10 for 30 bucks and 55 to 60 ford window crank replacements 4 for 60 bucks. They are the correct gear to fit my stock window cranks, Just had to drill and tap them for screws that hold the handle tight... Any ways 90 bucks and some help from a family member thats a machinest... Thank god for him, cause this truck would never have been done without his help. here ya go. 4 window switches.
#519
#520
Thank you... I Like the spal brand, I ordered there door lock actuators.
Ya they turned out pretty good, thats what the inner 4 holes are for is for role pins to act as stops for just such an occasion. I also thought about drilling out the gear splines on the window handle it self, that way it would just spin semi free if to much toque was applied... Ill get it together and see how it feels.
Thanks guys....
Thanks guys....
#522
#523
Well I guess I better stop creepin' and make a profile, i've been lurking for quite a while haha. I have to say this is one of the sexier things i've ever seen...Maybe after I get out of college I can stop drooling and start building! I have a 96 tacoma I want to do a 4bt and SAS treatment to as well, but a full size truck is more practical me thinks, and two truck projects is something I probably shouldn't do.. I have fallen in love with the 67-79 crews and have dreamt of pretty much what you have created. Whatever you do don't delete the pics, someday I might need a little help Keep it up, you sir have something great here
#524
