72 crew cab long bed cummins
  #421
Old 10-14-2014, 06:07 PM
blue04.5's Avatar
blue04.5
blue04.5 is offline
Whose wiring harness are you using.
Truck is looking good, coming a long nicely.
  #422
Old 10-15-2014, 08:58 AM
highntight's Avatar
highntight
highntight is offline
thank you....
I bought one from speedway motors..... its color coded and labeled every few inches... not a bad kit, I'm really happy with it.
  #423
Old 11-07-2014, 04:39 PM
highntight's Avatar
highntight
little progress. but been playing around with the stereo bezel. turned out pretty good. went a little different route then most of what I have seen.
  #424
Old 11-07-2014, 05:00 PM
MIKES 68 F100's Avatar
MIKES 68 F100
MIKES 68 F100 is offline
I really like your ash tray /toggle switch area !! i might just copy that !
  #425
Old 11-07-2014, 07:04 PM
highntight's Avatar
highntight
Do it..... It was really easy I wanted to run an air toggle in one but just didn't quiet have the room.
Thank you
  #426
Old 11-07-2014, 08:23 PM
f100today's Avatar
f100today
f100today is offline
Bad *** build. Gotta love the cummins and in a crew too boot. Awesome!
  #427
Old 11-07-2014, 10:53 PM
highntight's Avatar
highntight
Thank ya sir....
  #428
Old 11-10-2014, 10:15 AM
highntight's Avatar
highntight
Made some visual headway this weekend finally. Felt good to see some.
  #429
Old 11-17-2014, 01:14 PM
highntight's Avatar
highntight
got the headliner cut and in turned out really well. never made one out of abs but I'm very happy with the out come.
got the rear door loom rubbers in. bought enough for all doors but there to small for fronts
built a bracket for the brake controller, sucked it way back up under the dash. It stuck out way to far.
  #430
highntight's Avatar
highntight
  #431
Old 11-17-2014, 02:02 PM
MIKES 68 F100
Abs headliner looks good , where did you get the Big piece ?
my original headliner is board is weak and almost falling apart so I was thinking of replacing it and covering it with material
  #432
Old 11-17-2014, 02:36 PM
highntight's Avatar
highntight
I got it local here in slc, laird plastics. About 50 a sheet, but no glue and no fabric material. the 16th inch was a little to flimisy so I went with 1/8th. I would think any industrial plastic place would have it in stock. One side is textured so thats the size I used.
I watched a few videos the other day and a few people were putting fiberglass and resin on the original boards and stiffening them up, may also be an option to look at.
  #433
Old 12-15-2014, 03:32 PM
highntight's Avatar
highntight
Well a few pics to add to the mess..... rear carpet in, front is in but not finished, give it a day to lay down and get some wrinkles out. put the rear seats in just to see them.
have a few more to post once i get pics tonight...
  #434
Old 12-16-2014, 01:27 PM
ChaseTruck754's Avatar
ChaseTruck754
ChaseTruck754 is offline
I like how the rear seat folds up like that. What is that originally out of?
  #435
Old 12-17-2014, 10:59 AM
highntight's Avatar
highntight
I bought the seats together fronts and rears out of an 05 or 06 dodge cant quiet remember. but 99.9 percent they would be the exact same for ether year. the 03 to 04.5 have a wider hide away bin under the front seats middle console, its the only difference I know of up until at least 06...
Quick Reply: 72 crew cab long bed cummins
