72 crew cab long bed cummins
#49
dang spring are way over priced... but got the rear springs today. went with skyjacker 93 dodge 2500 6" springs... another 500.00 bucks yay. got all the old stuff off tonight and there gonna work great. ordered some axle perches that are adjustable. so i can move the axle back for the inch im gonna loose. but everything will bolt right up to the original hangers and hardware. and i went with the six inch spring so i wont have to flip the hangers. ill probably end up running a small 2" block still but thats ok.
out with the old in with the new
#50
got more done this weekend got the springs and axle on fri drank way to much all day saterday and finished switching body parts on the 67 today i forgot to grab some picks wit the new front end on it.
slow but sure... i ordered a bunch of stuff from ballistic fab. got to give them props. great quality, way cheap, and really fast shipping.
#51
Your moving along nicely your farther then I am is that the stock spring mounts and position? The dodge leafs for a 93 fit right in and have the proper shackle angle? I got my rear suspension almost done got it all mounted up and figured I'd try some of the stock rear leaf mount holes for my SD hangers lowered the truck down and need to move the rear hangers back another 2" or so to get the right shackle angle got some pics of it ill put up then atleast she's a roller again
#52
Right on. Good deal. I was wonderin where ya been. I was watchin for an update on ur springs. Get that sucker done. Ya I'm right there with ya. She's rolling again. I just tached my axle perches on. I set the pinion angle at 10. I figured that was plenty safe. And yes I ended up goin with the 92 93 dodge springs. Fliped them around and they bolted right up. I snaghed some ajustable axle perches from ballastic fab .com so I can move the axle forward one inch. When its compressed it sits perfect. Stock placement on the hangers. I think with all the weight on them there gonna be perfect.
#53
The dodge springs just needed flipped so the center pin would be in the stock place so your using the rear of the leaf as the front is this right from what your saying? Ballistic does sell some great parts I got some from them for my truck are the adjustable perches the ones that have 3 holes in them for different positions? If so I have them to I got some of there rear Dana 60 disc conversion caliper brackets but I have no use for them as I'm going with a Dana 80 or sterling 10.25 whichever I find first
#54
you guys are moving right along looks good. highntight i told you you got me motivated i went out this weekend and got the front clip off of the 72. Now i just have to take the 300 out and plate the frame and build a new crossmember. I have pics on oldfordcrewcabs.com under the diesel section
#55
Yep. I didn't intend on flipping them at all. It just worked out perfect if i did. And yes the three hole adjustable ones. When do u think ur gonna get your hangers moved.
And smitty that's bad a I'm gonna go check it out. What size plate and you gonna box ur frame In with. I need to order plate this week so im currious.
#57
#58
#59
